TIME SLIP DATABASE
drag race tonight
Old Oct 11, 2015 | 11:58 AM
  #21
white00's Avatar
Originally Posted by George C....
Very simple...whats his trap speed? Its not in the 160s+
You still gear for max power crossing traps
Dont know, but its a street truck from what i can see racing the 1/8 mile. Im not understanding why that truck with its mod list isnt making enough hp to run real quick in the 1/8. It has to damn sure be making enough torque to push 3.42 gears in a rcsb pickup. There not that heavy..
Old Oct 11, 2015 | 12:34 PM
  #22
George C....'s Avatar
Formerly ScreamingL
If racing 1/8 then you wpuld want even more gear
342 isnt for most turbo trucks
Old Oct 11, 2015 | 12:37 PM
  #23
TXsilverado's Avatar
Dont fear the gear. Especially in a heavy *** truck. Who started the turbo needs low gear myth anyways?
Old Oct 11, 2015 | 01:16 PM
  #24
white00's Avatar
maybe its a myth and maybe its not. But there are plenty of trucks running very hard with those gears and have been for a long time thats all im saying...
  #25
white00's Avatar
ok.....
Old Oct 11, 2015 | 01:23 PM
  #26
Formerly ScreamingL
In the end you still want max rpm thru traps...342s dont put next to any truck thru traps at max rpm
Majority of turbo trucks are far under geared based on thr myth
Old Oct 11, 2015 | 01:25 PM
  #27
white00's Avatar
I get that. But based on the myth i have seen a truck close to his build with a 4l80e and 3.42 gear run 6.7x in the 1/8 on pump gas
Old Oct 11, 2015 | 01:37 PM
  #28
Formerly ScreamingL
You realize thr OP is on very little boost
Old Oct 11, 2015 | 01:43 PM
  #29
white00's Avatar
Well maybe that explains it. How much boost is he on because it looks to leave very strong at the track but then just falls off. The truck i was talking about was only on 12.5 pounds of boost when it ran 6.8x in the 1/8
Old Oct 11, 2015 | 03:21 PM
  #30
Atomic's Avatar
I have a gauge for that
3.42s would be pretty good for a 24" tire
The whole myth of high gears are better suited for turbo cars I think stems from the fact that you will see boost faster compared to rpm with a higher gear, but you will in fact be slower. So would you rather make boost or go faster? If you just want to make boost then never use 1st gear and there you go.
