TIME SLIP DATABASE
drag race tonight
Old Oct 10, 2015 | 07:57 AM
TXsilverado's Avatar
7.50 and dipping into sixes is a pretty big difference what happened?
Old Oct 10, 2015 | 12:08 PM
white00's Avatar
Put those 3.42 gears in it, get a taller tire(29" to 30" tall) and let that torque put some work in to move that truck!!!😀
Old Oct 10, 2015 | 12:09 PM
GMCtrk's Avatar
His gears are fine.
Old Oct 10, 2015 | 03:46 PM
tim wellington's Avatar
Default time
not my best et .my test pass I blew times off so took power out . 3hrs later track much better .should had left power in.
Old Oct 10, 2015 | 03:53 PM
white00's Avatar
Originally Posted by GMCtrk
His gears are fine.
Maybe but ive personally seen a couple of rcsb trucks with nothing more than a 3.42 gear and taller tire run quicker. I have seen his truck run several times also. If that gear is fine then he needs to step up to a taller tire or revisit the tune. Look at his mod list and tell me how quick you think it should be running.
Old Oct 10, 2015 | 10:30 PM
ZO6Ted's Avatar
How much is a bigshot?
Old Oct 10, 2015 | 10:45 PM
gamble686's Avatar
In this case the longer 1st gear of the 80e doesn't lend that well to 3.42s. The 4.10s are helping it get moving and load isn't an issue unlike some trucks whose housing is likely too small.
Old Oct 11, 2015 | 09:03 AM
George C....'s Avatar
Formerly ScreamingL
342 will not help him...he isnt making power to require them
His truck can run faster with his current tires and gearing
Old Oct 11, 2015 | 11:10 AM
white00's Avatar
Not getting into no pissing match but how much power does he need with that set-up to require them? Tim, how much hp are you making? Ive seen several rcsb trucks with a 3.42 gear run 6.80 to a .90 in the 1/8 mile and one was a 5.3 truck.
Old Oct 11, 2015 | 11:20 AM
Formerly ScreamingL
Very simple...whats his trap speed? Its not in the 160s+
You still gear for max power crossing traps
