TIME SLIP DATABASE
Dig racers need a little help
Old Mar 5, 2014 | 03:54 PM
silverado.408's Avatar
Default Dig racers need a little help
Phantom / Dirt track racer / And body else how did you get your nitrous or even turbo trucks to hook on the street. Caltras (assassin bars)/ Sticky tires/ What else? I need the truck to dig. Funday Sunday in Mexico! - YouTube
Old Mar 5, 2014 | 04:11 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
Stock suspension and street tires!
JK. Tyler doesn't know anything about hooking a truck! Don't listen to that guy, lol.
I keed I keed. Sticky tire will go a long way. Caltracs help out tremendously. Pre-loading suspension.
Old Mar 5, 2014 | 05:01 PM
What about something like a muscle(sway) bar on the rear. If cars can push leaf springs into low numbers a truck should be able to do good.[IMG][/IMG]
Not the ladder bar but the sway bar
Old Mar 5, 2014 | 05:55 PM
dirt track racer 81's Avatar
What beau said, don't listen to me..
Phantoms video, that day was badass, we were at that spot for 3+ hours and never got ran off.
Of coarse you'll need slicks. I like assassin bars a lot better because you have a lot more adjustability. You want the front of the bars to be has high as you can get them and put in the bottom hole on the axle housing. The harder you hit it the better it hooks, to a point. And get a hold of some pimp juice..
Old Mar 5, 2014 | 05:58 PM
RacinRust's Avatar
X2 on the sway bar ! Will help level things out and help transfer more torque back to the left side. If you can afford and set up the splined bar thats the way to go. But a simple bolt-on bar with adjustable end links are way better than no bar. Hellwig makes a very easy kit that installs in a couple of hours. So many other options as well that gets those leaf springs working.
Old Mar 5, 2014 | 06:03 PM
TXsilverado's Avatar
i've never done it on the street, but after last weekend, i'm a firm believer in double adjustable shocks. my first run it hit the tires too hard for a 2.0 spinning. 1 change to the extension settings on the shocks put it at 1.59. it was on a prepped track, but i'm sure it's even more important on an unprepped surface.
also, i think a lot of people over tighten their suspension components (including me in the past). everything should be able to move around freely.
Old Mar 5, 2014 | 06:11 PM
Phantom's setup flat out works from what I have read and seen on YouTube. The shocks I'm looking at are the Rancho rs9000 I believe. I think Atomic runs them. Full adjustable coil overs are not in the budget right now. So Assassins are better noted/ any sway bar better than none check/ adjustable shocks and weight relocation is in the processes. OK cool. Thanks guys Ill post pics on my build when I get things moved around and welded up in the next week. If I can remove some weight I might be able to pull a tire or to......... yeah right
Old Mar 5, 2014 | 06:13 PM
Dirt track racer I saw your vid of the street hit/test. Sounds mean as hell
Old Mar 5, 2014 | 07:19 PM
I've got qa1 dirt track shocks. This was on fresh asphalt and figured it would blow the tires off, hooked pretty good, still spun some.
http://youtu.be/sx5R7sXWgRQ
