TIME SLIP DATABASE
Congrads Stock48, 10.65@126.99
Old Apr 1, 2008 | 11:13 PM
  #71
stock48's Avatar
9 Second Truck Club
Originally Posted by parish8
i totaly maxed out a turbonetics t76 and couldn't run in the 10's. had to add a little nitrous to get it done. i also had a tail wind. cold night, 1500' elevation, open down pipe. like i said, he is doing something right
whats the specs on that turbo? is there drastic weight reduction on the truck or just the normal stuff?
What were your cam spec's, and shift point's? That drasticaly effects the efficiency of the turbo/ engine combination. If you exceed the turbo's max LB/ min of air before you reach peek HP you are fighting yourselfe. I lost 3PSI just by porting the heads. My shift point's are @ 5400RPM. I go through the lights at around 5800RPM.
Old Apr 1, 2008 | 11:14 PM
  #72
stock48's Avatar
9 Second Truck Club
Originally Posted by Derek @ EDO
hmm, I have the GTK s trim.
I wonder how much boost i could run @ - DA on my 370
What size?
Old Apr 1, 2008 | 11:27 PM
  #73
Derek @ EDO's Avatar
FormerVendor
76mm .96 ar
Old Apr 1, 2008 | 11:37 PM
  #74
stock48's Avatar
9 Second Truck Club
76mm .96 ar
I feel confident I can hit ~ 20PSI @ sealevel with mine,. (at least before I ported the heads). Just need to keep the RR's below 6K. I have blowen up two turbo's allready up hear trying to make boost.
Old Apr 1, 2008 | 11:49 PM
  #75
FormerVendor
I wanna run 17 to 18 lbs.
Here are my build specs:
forged 370 9:1 CR using a VIC jr manifold with WCCH Edelbrock 72cc 215's
Custom reverse split spec from Rick @ Synergy
T-76 s trim .96 AR, basically a GTK 1000 without the black cover.
Alky contol meth kit
FLT level 4 80e
2 step, possible trans brake. haven't decided yet.
For now stock 80E TC with 3.90 gears
A 50 dry shot of NX
3" DMH E-cutout as far up as i can put it!
My truck is a 2wd and probably weighs about 4200lbs.
I want low 10's!!
Old Apr 1, 2008 | 11:57 PM
  #76
stock48's Avatar
9 Second Truck Club
Also note the higher the RPM the more loss you are going to get through your I/C. At sea level a 6.0L @ 20PSI will consume ~76 LB/min, a T76 can flow 93 LB/min maxed out. That's with no I/C loss factord in. Figure a 10 LB/ min loss on top of that. So at 5500RPM @20PSI you will need around 86 LB/min which is pushing the T76 to the max. Figure in my 3-4 PSI loss for altitude and you get 16PSI, and that is about what I have seen. Try to spin that 6.0L 6500RPM, and you need 100+LBS/min, and that is T88 territory. So why cam your engine to make Peek power at 6K + RPM? Your engine combo, and turbo need to be able to work together to get maximum efficincy.
Old Apr 2, 2008 | 12:01 AM
  #77
stock48's Avatar
9 Second Truck Club
76mm .96 ar
What size engine, and cam specs?
Old Apr 2, 2008 | 12:02 AM
  #78
JJ_TURBO's Avatar
11 Second Truck Club
Just what I was about to say J/K
Old Apr 2, 2008 | 12:16 AM
  #79
FormerVendor
The cam specs are classified as per Ricks request. My 370 is 6.2l
Its cammed to spin to about 6200
Old Apr 2, 2008 | 01:38 AM
  #80
stock48's Avatar
9 Second Truck Club
You will be borderline at 18PSI. 16~17 should be attainable. Also your GTK might be alittle more efficient than what Im accounting for.
