TIME SLIP DATABASE
Congrads Stock48, 10.65@126.99
Old Mar 31, 2008 | 09:14 PM
  #61
stock48's Avatar
9 Second Truck Club
Originally Posted by parish8
that really is a killer time. you must be doing something different than i was.
i ran a 10.91@122 at 13psi and a little nitrous. t76 nearly maxed out, 6.0 with a cam. turbo kit was pretty much identical to what you have. engine and tranny was about the same, converter the same. my 60 was more like a 1.68. track at 1500ft and a 50 deg night.
congrats. your doing something right!!
Thank you for that. Weather you realise it or not you helped me alot, and probably alot of others by posting, and sharing information you learned on your truck. You pioneered the turbo **** on these trucks, and put it all out in the open, for all of us to see. I respect that alot.
Old Mar 31, 2008 | 09:21 PM
  #62
Derek @ EDO's Avatar
FormerVendor
I bet a cutout would help you out a little!
Old Mar 31, 2008 | 09:37 PM
  #63
stock48's Avatar
9 Second Truck Club
I really wanted to uncap the exhaust, but It was hot, and I didn't feel like getting burned. I was also afraid it might lean me out. I need to go out one of these night's and try it out. Im going to add one more meth nozzle, so it should be ok. I have a 375 I want to add.
Old Apr 1, 2008 | 04:24 AM
  #64
Wilde Racing's Avatar
How do I change this text
I was thinking the same thing (doing something different than I was). I just don't get it HUGE numbers with big turbos and cams, HUGE numbers with small turbos and cams..... WHAT the hell? lol
Old Apr 1, 2008 | 08:42 AM
  #65
TrickTurbo's Avatar
Truck Sponsor
He's working the snot out of the turbo. almost to the peak out put.
Old Apr 1, 2008 | 04:38 PM
  #66
parish8's Avatar
single digit dreamer
i totaly maxed out a turbonetics t76 and couldn't run in the 10's. had to add a little nitrous to get it done. i also had a tail wind. cold night, 1500' elevation, open down pipe. like i said, he is doing something right
whats the specs on that turbo? is there drastic weight reduction on the truck or just the normal stuff?
Old Apr 1, 2008 | 04:45 PM
  #67
thunder550's Avatar
High on diesel fumes
Old Apr 1, 2008 | 10:54 PM
  #68
stock48's Avatar
9 Second Truck Club
Truck was full weight, only thing removed was the spare, and tail gate. I still have the A/C, stock bumper, hitch etc. I was also running with over 3/4 of a tank of fuel in the stock tank. Had my tools, craptop, and some other **** in the truck too. I fucked something up in the fuel bucket so If I launch with less than 2/3 of a tank it falls on it's face. Truck was around 4900LBS before the turbo, 80E, and big drive lines. Has to be at least 5000~5100 LBS. One thing I did have was I rigged up a redneck ram Air that might have healped a bit. My truck makes the most Boost in 3rd gear, and i wasn't watching the boost gauge, I had my eye on the 12.2 AFR. Da was around 7000' when I ran. Temp was about 50 deg, with a cross wind. Barometric psi was 24.4 HG.
Old Apr 1, 2008 | 11:00 PM
  #69
stock48's Avatar
9 Second Truck Club
Turbo is a water cooled Ball bearing turbonetics T76, .96AR, p wheel. It is not the normal T series, it is the next one up, but not the GTK. It was making 16PSI up hear @7000' elevation, until I ported the heads. After the heads boost droped to ~13PSI. Down in Pueblo @ 5000' It tried to hit 18psi, and I had to turn it down.
Old Apr 1, 2008 | 11:06 PM
  #70
FormerVendor
hmm, I have the GTK s trim.
I wonder how much boost i could run @ - DA on my 370
