TIME SLIP DATABASE
Best leaf spring setups
Old Jan 12, 2006 | 04:09 PM
turbo22rej's Avatar
Default Best leaf spring setups
Alright guys who has some secret voodoo to make your leaf springs work like magic at the track. Slapper Bars, Leaf spring upgrades, Ladder bars, trick shocks, tires, Viagra w/e......... Post up setups, pics, 60' times, vehicle, approx hp...............................
Old Jan 12, 2006 | 06:25 PM
MR Marine's Avatar
Caltracks stock springs Rancho shocks 1.37 60' M/T Street Radial 18 psi
Old Jan 12, 2006 | 08:37 PM
v8
17,16,15,14,13,12,11 Drvr
stock 1.74 60' with a 2500 stall. 299 hp
Old Jan 12, 2006 | 09:18 PM
TURBO8's Avatar
I would be very happy if I could run 1.74 or lower. I have caltracs mt drag radios and hotchkis lowering spring (4 in) stock shocks. To the track in two weeks!
Old Jan 12, 2006 | 09:47 PM
v8
what gears you running with the t-56? you should beable to get a 15? 60' with that setup. good luck.
Old Jan 12, 2006 | 11:36 PM
TURBO8's Avatar
I am hopeing for traction. I have 3.73's, I have not put the DR's on yet.
Old Jan 17, 2006 | 08:04 PM
TURBO8's Avatar
I Think I May Have Traction. I Installed The Caltracs This Weekend And They Feal Really Good. If I Poped The Clutch At 2000 Rpm Before Caltracs, I Would Be Bucking And Going Sideways For A While. I Just Tryed The Same Thing And My Tires Just Churped And I Took Off. I Had My 20's On, The Truck Was Running Like Crap Thow. I Am Impressed With The Caltracs They Really Worked For Me. I Also Cut A Rubber Heater Hose And Put It Around The Top Bolt That Rest On The Springs, And I Have No Squeeking At All. I Drive With Them Preloaded And They Feal Good. I Just Have To Find This Boost Leak, And Then Take It To The Track. The Leak Is Driving Me Crazy, I Cant Find It.
Old Jan 17, 2006 | 08:34 PM
bluecajun5.3's Avatar
11 Second Truck Club
stock suspension, 1.75 60' on m/t et streets 26x11.5x16's
Old Jan 17, 2006 | 09:22 PM
litreddevil's Avatar
Banned
m/t drags with 5.3 1.64. I tighten the bolts on the shackles then back it up a little to let the rear move a little looser to help
Old Jan 18, 2006 | 01:54 PM
Scream's Avatar
MOOBIES Moderator
1.75 on 275/55-16 M&H DR's. Caltracs w/ overload leaf removed, not yet dialed in.
