Best 1500 extended cab GM 60' on STREET tires?
I'm curious, what's the best 60' ever accomplished with a 2WD extended cab GM on street tires - not drag radials - STREET tires!
Please post your 60', tire brand/model/size and race weight.
I pulled a 1.96 on 275/60R17 Toyo Proxes with 4,935lb race weight.
i pulled a 2.2 on 275/60/16 Toyo Proxes S/Ts
i ran a 14.92@91.65....
Im just starting... My G-80 wasnt coperating with me so i couldnt lauch it with all she had.
I've pulled several 2.2's on my proxes, a 2.10 one time and then a 1.9 that toar the teeth off the ring gear
Originally Posted by silver-mod-o
my best so far has been a 1.90 on some 255 wide Toyos @ 13 psi and a 4200 lb race wight.
You're disqualified for being at the weight of a regular cab
how did you strip that pig all the way to 4200lbs?
