TIME SLIP DATABASE
Another 1/4 mile time ? (Sorry)
Old Jan 28, 2012 | 01:22 PM
Petey62782's Avatar
MASS seller approved
Default Another 1/4 mile time ? (Sorry)
I know u guys get this quite often so I hope u guys don't mind one more. The truck is a 2002 avalanche 1500. It has 4.10 gears with a eaton posi in the rear. Running on stock 17" rims. The engine is a LQ -9 with a TBSS intake and edelbrock P&P 90 mm TB, dynatech long tubes and high flow cats, Gibson cat back, flex-a-lite 282 twin fans, trick flow UD pulley , thunder volt wires, now internal --243 heads with PAC 1518 springs and Harland sharp 1.7, comp PR, ls7 lifters and a pat g spec cam 218/222 .598”/.602” 114LSA +1. The trans is a FLT 4L65 lvl 5 with a yank 2600 stall the tune currently is a Nelson but will be switched to Blackbear but either one is close to the same. So to make a long story short do I have a chance of getting into 13's or better what time do u guys think
Old Jan 28, 2012 | 04:33 PM
Petey62782's Avatar
Bump......anyone?
Old Jan 28, 2012 | 05:50 PM
lglowe's Avatar
Mid 14s my guess. Avalanche is heavy.
Old Jan 28, 2012 | 05:56 PM
custm2500's Avatar
Ph.D. in HUBRIS
If you don't run a 13.99 I would find a bridge and drive the truck off of it.
Depending on traction you may be low 14s but you should be able to get a 13 second slip.
Old Jan 28, 2012 | 06:55 PM
DTHPROOF's Avatar
Definitely 13-something. I'm sorry it's vague, but it's the best I've got lol. And ditto on the bridge.
Old Jan 28, 2012 | 07:03 PM
Petey62782's Avatar
If I get to the 13 s that would be nice because I got a tundra that has been pissing me off that I would live to smoke
Old Jan 28, 2012 | 08:33 PM
silverz28camaro's Avatar
Whats keeping you from racing him?
Old Jan 28, 2012 | 09:58 PM
Black08Chevy's Avatar
I say low 14s due to the avy being heavy
Old Jan 28, 2012 | 10:23 PM
ak2007r6's Avatar
High 13's low 14's
Avs are kinda a tank...
Old Jan 28, 2012 | 10:59 PM
LsxCody's Avatar
It will probably be in the 14s. Small cam and stall.
