TIME SLIP DATABASE
28/10/17 slicks info
Old Feb 4, 2015 | 05:49 PM
George C....'s Avatar
Formerly ScreamingL
Originally Posted by Byrdman11
I was doing 1.8's and a best 1.81 on NT05R street tires. So I think 1.7s should be easy. I have a ams 500 boost controller with CO2 and 2wd with Caltrac's
leaving with no boost but 6000 ish rpms i would net 1.65-1.66 with a 5.3 at 18psi in tires
14-15 range netted high 1.7s
16-17 range netted low 1.7s
when i stayed 17.5-18.5 it was consistant at 1.65-1.66 for most tracks i ran at
ran same tires on my lightning with stock stall, stock suspension and no traction bars netted 1.72s at 18psi this was leaving slightly above idle with stock Eaton
GMCtrk's Avatar
Is this truck 2wd or 4wd? 1.7x 60' is leaving a ton on the table in terms of 1/4 mile time.
Old Feb 4, 2015 | 06:09 PM
Byrdman11's Avatar
2wd truck
Old Feb 4, 2015 | 11:32 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
ill agree with George C I'm running same tires and 18LBS to 20LBS is were they like to be anything lower then that it wouldn't 60ft as good
Old Feb 5, 2015 | 06:24 AM
Byrdman11's Avatar
Well guys I'm going to set them 19lb cold and do a small burn out and let them eat.
Old Feb 5, 2015 | 07:00 AM
pittman's Avatar
Originally Posted by Atomic
Mine worked better at 16psi or so.
I seem to do best at 16 psi as well, but I am running 16" rubber
Old Feb 5, 2015 | 08:22 AM
Formerly ScreamingL
The compound on these specific Hoosiers need to be ran higher
Old Feb 5, 2015 | 02:10 PM
Choda's Avatar
large range of pressures... thats fine. try them all man and let us know what works for you
Old Feb 6, 2015 | 04:53 PM
BigKID's Avatar
18psi seems to be the magic number for me with a 28/10.5/16 Hoosier on 9.5" wheel. When I had them on the 7" wide stockers I had to run lower pressure for the footprint but they would sway bad on topend.
Old Feb 6, 2015 | 06:08 PM
bingo!! the 17s have a softer compound then the 15s and the 16s
i was cutting 1.6 60ft with 20lbs
