TIME SLIP DATABASE
28/10/17 slicks info
Old Feb 3, 2015 | 09:18 PM
Byrdman11's Avatar
Default 28/10/17 slicks info
Guys checking to see if anyone has any info on these slicks. Like pressure and does this slick like big burnout or a short burn out. Please help
Old Feb 3, 2015 | 09:20 PM
George C....'s Avatar
Formerly ScreamingL
18 to 20 psi
Small burn out
Old Feb 3, 2015 | 09:21 PM
Byrdman11's Avatar
Is that air pressure hot or cold?
Old Feb 4, 2015 | 05:33 AM
Formerly ScreamingL
Cold
Lower makes them hook worse and best to use them on least 9" wheel
Old Feb 4, 2015 | 06:20 AM
Atomic's Avatar
I have a gauge for that
Mine worked better at 16psi or so.
Old Feb 4, 2015 | 06:29 AM
Byrdman11's Avatar
These Hoosiers slicks are new to me also slicks on a 5800lb truck too.
Old Feb 4, 2015 | 08:22 AM
Formerly ScreamingL
Honestly not enough footprint for your truck unless 4wd and have good boost controller
Old Feb 4, 2015 | 10:01 AM
Choda's Avatar
with my slicks, i always did a burnout like this
roll through water box
get them spinning in 1st, right into 2nd. hold rpm around 4500
hold until whitish smoke
roll out a car length and ease off throttle
i would think 15-16 psi. test and tune my friend.
At my local track I could get 8-10 passes no prob. make 2 at 17psi, then 2 at 16, then 2 at 15. keep burnouts and launch rpm the same. Compare slips
Old Feb 4, 2015 | 11:15 AM
Formerly ScreamingL
When I ran less then 18 my 60 lost..went into the 1.7s
Old Feb 4, 2015 | 05:32 PM
Byrdman11's Avatar
I was doing 1.8's and a best 1.81 on NT05R street tires. So I think 1.7s should be easy. I have a ams 500 boost controller with CO2 and 2wd with Caltrac's
