TIME SLIP DATABASE
28/10/17 slicks info
Old Feb 6, 2015 | 08:27 PM
  #21
Byrdman11's Avatar
Guys thanks so much for the tire info. I will report back after Saturday.
Old Feb 8, 2015 | 09:14 AM
  #22
Byrdman11's Avatar
Guys the tires did great on a suck *** track. But do to not able to build boost off the line I only cut 1.79 60ft. I'm in the planning stages to fix this. Trans brake or hydro boost
Old Feb 8, 2015 | 08:19 PM
  #23
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
what did you end up running for PSI
Old Feb 8, 2015 | 08:33 PM
  #24
Byrdman11's Avatar
16lb like on the dyno.
Old Feb 14, 2015 | 07:32 PM
  #25
Byrdman11's Avatar
Guys the slick are yelling help but 18 cold so far is the number. 1.67 60ft
Old Feb 15, 2015 | 10:07 AM
  #26
tim wellington's Avatar
Default slicks
when I run less than 18 .slicks will hook and then spin on rim. mark a spot on rim going by valve stem .also this really going based on power.you have to watch slicks low air pressure can cause wheel spin because when tire wrinkles the footprint gets a part of tire that doesn't touch track cause tire to slip
Old Feb 15, 2015 | 11:47 AM
  #27
thewrx's Avatar
Start high and work your way down, no need to go unecesarily low on psi.
Old Feb 15, 2015 | 04:26 PM
  #28
Byrdman11's Avatar
I install rim screw to stop the tire from spinning on the rim. The tires are catching hell trying to hook up and move 5500lb. I may use a old 10.5 outlaw trick by installing tubes in the slicks. The tires are chattering bad at about 100ft out when more boost is ramping in.
Old Feb 15, 2015 | 04:33 PM
  #29
George C....'s Avatar
Formerly ScreamingL
as i stated in post 7 not enough foot print for your truck, when i turned my truck up to 18psi i would haze them on a well prepped track on a 3-4 gear change
they are a decent tire for lower HP/tq vehicles but nothing of power unless they are stretched on a 11" rim
Old Feb 15, 2015 | 04:55 PM
  #30
Byrdman11's Avatar
George, I thinking about bigger slick. But that would be much later in the year. I'm just going to get the truck to be a little easier on the tires and ramp in smoother.
