TIME SLIP DATABASE
26 inch rear tire for drag racing????
Old Apr 24, 2011 | 10:29 AM
SICKSIXTYSEVEN's Avatar
Default 26 inch rear tire for drag racing????
I was thinking about running a hoosier Drag radial 26 inch diameter for drag racing at the track. this is obviously a big step down from the stock 2011 silverado tire diameter. any opinions on this.. pros cons?? it would be on the stock wheel.
Old Apr 24, 2011 | 04:23 PM
slow2500's Avatar
Registered User
It will look a little goofy but should work ok. A DR isn't usualy your best bet on a truck but if you aren't making a ton of power you should hook ok on it.
Only con is if you can't make it to the stripe without shifting into OD. What trans and gear do you have? What is the stock tire height?
Old Apr 25, 2011 | 12:57 AM
2007chevy5.3l's Avatar
I would be careful. The NNBS oem driveshafts are only good till 90ish mph then vibrate like hell and blow up. Youll be spinning the hell out of that shaft if you have tall gears with that tire set up. Critical speed on the shaft will take over and blow it...
Old Apr 25, 2011 | 02:11 AM
BadAssChevy327's Avatar
i think all motor with anything longer then a 4,10 a 26 is perfect
Old Apr 25, 2011 | 05:24 AM
Black'Rado's Avatar
ive got a set of mickey thompson et street radials in 26x10.5 on factory 16s and they work good at the local 1/8th mile.
ive added more power so im loooking to step up to a 28in tire.
Old Apr 25, 2011 | 06:35 AM
pittman's Avatar
I've hit 1.57 sixtys on the 16" ET Streets using the stock rims.
Old Apr 25, 2011 | 07:07 PM
Truck is a 2011 Silverado put down 360 RWHP 377 on a Mustang dyno with ARH, Volant, Borla race muffler, and a tune..
The pulls were made in 4th gear and ive seen 125 on the stock driveshaft. it was vibration free on the dyno and street. Maybe cause its the 6.2 truck with Z85 tow package???
Old Apr 26, 2011 | 01:58 PM
RandTx's Avatar
Lot of guys run MT 295's, the advertise as 27.2 ??? but are closer to 26 1/2" tall.
Old Apr 26, 2011 | 08:56 PM
silver-mod-o's Avatar
Hunt&Fisherator
You should pick up plenty with the 26's... on a truck like yours a short tire is your friend
Old Apr 26, 2011 | 11:23 PM
see my other post track numbers def needed a shorter tire
