TIME SLIP DATABASE
26" drag radials...vs 28"+
Old Oct 19, 2006 | 02:01 PM
Superado's Avatar
11 Second Truck Club
Default 26" drag radials...vs 28"+
if a 26" tire will hook the truck, don't you get the added benefit of the gear ratio change due to the smaller diameter tire?
In other words, if I am running a 31" tire and spinning bad...if I use a 28" tire, my .370 gear then reacts close to that of a .411 w/ a 31"...a 26" tire having the same effect...lowering the ratio to close to that of a .456 w/ a 31" tire?
Old Oct 19, 2006 | 02:19 PM
Taylorkdt's Avatar
I a 373 rear end and on 31x10.5 i was crossing at 4400 I swapped to 26 drag radial and I crossed at 5800 went from 13.3 to 12.98 just changing tire.
Old Oct 23, 2006 | 02:27 PM
Superado's Avatar
Originally Posted by Superado
BadApple...
I hate I didn't get a chance to meet ya' the other day...I didn't get to meet Matt either...he was at school when I rolled thru the big city of Lyons, GA...and damnit...is that ride from Cordele a long *** road of nothing or what?
I got the tires though...just debating on the wheels now...I found a 17"x8" steel wheel at Summit on clearance for $59 each...w/ 4.5" bs...???
What do you guys think about these wheels? Is there no one out there with a 6-lug lightweight race wheel? I can't seem to find one...
I would prefer much more bs, but these are the only ones I can find w/o buying custom wheels...and these are for the track only...
Old Oct 23, 2006 | 02:31 PM
redwagon's Avatar
not only do you get the benefits of numerically higher gear ratio, you also gain the rotational inertia with shorter tires that you wouldn't get with 4.11's and tall heavy tires.
walledition
Feb 24, 2026 03:27 PM
kainzien
Nov 10, 2023 11:37 AM
Slammed silverado
Sep 28, 2015 06:14 PM
BlackGMC
Sep 21, 2015 01:48 PM
