TIME SLIP DATABASE
17.45
Old Sep 5, 2010 | 11:39 AM
Saber123316's Avatar
Default 17.45
So i took my rig to strip the other night.
17.45 new best time.
old best was 17.99
not bad coming from a 1996 lifted 4x4 F-150 with stock trans and stock 351 sitting on 35x12.5r15 tires and 3.55 gears.
I did one mod to my truck to get that time. I put a K&N FIPK on part no. 57-2543.
I can't wait to put the new VB and torque converter in with the 4.10's
gonna pull the lift out as well and run 265's
Old Sep 5, 2010 | 11:43 AM
RibeiroBJJ's Avatar
Praise The Lowered
Good Job..dropped a 1/2 second..Are you sure you have a 351...isn't a 5.4 a 331 ci...Not a ford guy so I am not sure about the 96 model...but thought it was either 4.6 or 5.4...Look into gears and exhaust/headers next
Old Sep 5, 2010 | 11:58 AM
1996 was the last year of the windsor motors in the fords. my truck is a 1996 model so it has all the benefits of OBD2 and the older engine that has a ton of aftermarket thanks to the mustang.
next mods are gonna be true dual exhaust with cut outs. over the winter I am buying light weight wheels and smaller tires. a torque converter and vb gonna keep the engine as stock as possible and see what I can get with just bolt on stuff before I do the H/C/I swap.
although the LS1 chevs make me want to sell mine.
Old Sep 5, 2010 | 02:43 PM
double047's Avatar
14 Second Truck Club
Good job congrats!
Old Sep 5, 2010 | 03:03 PM
SincalT/A's Avatar
Is there tuning support for the truck?
If so what kind?
Btw..thats a good start on et drop.
What trap speed?
Old Sep 6, 2010 | 03:30 AM
If so what kind?
What trap speed?
oh yeah theres tuning support probably SCT thats what some guys at NLOC told me. I am gonna give them a call in the morning gonna probably order up a
I trapped 76mph in that run. so my truck is shifting right and I know how to drive the damn thing ( how hard is it put it in drive and floor it) no real skill at 17 seconds.
but its a start and now im looking at getting a 351 block a set of heads a rotating assembly 8:1 pistons and a turbo
Old Sep 7, 2010 | 09:34 PM
silverz28camaro's Avatar
Any pics of the truck?
the tires and gear combo are killing you the most.
The good thing about running a 17 sec. 1/4 is that its not hard to shave the next few seconds off your time. Now if you start to get to the low 14 sec range you'll find its beggining to require real power to go even 1 sec. faster.
Old Sep 7, 2010 | 11:01 PM
06Sierra2's Avatar
i agree with ^^ 35's with 3.55's need to go imo. post up after u run those 265's. i just ordered 4.10s on a 31.5 tire on 22's coming from 3.23's right now. how much can u really drop et with a swap? i heard its very minimal
Old Sep 8, 2010 | 12:29 AM
goal is to go 13.99
I figure.
4.10s 265's lift removed back to stock traction bars 3000 stall converter
long tubes e-fans MSD 6al MSD coil, should = 16.5
truck weighs around 5000 with 250 rwhp should put me 15.8-16.0
H/C/I should put me around 325hp if im correct with those mods I will do the fuel system as well, custom tuned by me, and running a 75 shot. im praying to hit 13.9 or blow up trying....
if that happens...
I got a 351 block coming to me in a week
