13.74 in my 07 classic ccsb
Thanks man. Looks like Im going back on the 27th with a few more mods. Putting my 36lb injectors on it, reflashing the ecu and putting a nx proton kit on it. Probably rock a 100shot that day. Hoping for some low 12s. Thatll have to do for now. Im to scared to run a 150 shot on a fogger nozzle. Especially on my 91 octane tune. Who knows maybe Ill nut up and rock some 110 octane and stray a 150 shot LOL
Yea I mean i have no doubt that your stock injectors arent keeping up. hell I ran out of my stock injector with bolt on mods only with my LQ9. You are also giving up a little on the top end, but probably not as much as you think. I could see maybe 10 HP around 6k, but honestly I wouldnt expect that cam to carry all the way to 6500 anyway. Spinning it that high you will definitely see some gains from the 87mm intake
Do you have any pics of your Exhaust? im looking to do a 3.5" side exit myself... is yours before the rear tire also?
Side note, you shouldnt be hitting 3rd gear until almost 90MPH depending on your shift point... is that the case? And yes, its such a long gear with 3.73's that I'm sure it doesn't feel all that strong.
sorry this double posted somehow...
Another thing though, density Altitude is more important that the actual elevation. Do you know the exact time you ran at? You can plug it into an online calculator to get more info on air density.
Ya it was around 2500-2700ft when I ran that day. Im shifting at 6300 and just ran it up that day for the dyno. My buddy has my exact same setup and his made 384whp with 36lb injectors. His hits peak at around 5700 and only falls off a touch to 6400. when I say it falls flat in 3rd I mean it falls WAYYYY flat. Definitely goin lean and pullin timing. I think the injectors will help a lot. My 3.5 inch is just before rear tire. Short 3.5 pipe to muffler and then it 45s shortly after muffler and keeps that angle to the back tire. Didn't wanna put a 90degree turn in it. This truck gained almost 10whp goin from 3in to 3.5in piping. These motors like flow.
Nitrous will be here soon and hopefully it runs strong on it the 27th.
My suggestion is for the street do this cam especially in a lower compression lq4. If you have milled heads for higher compression and a stall over 3k the next cam up may be a good choice. Hope this helps.
drummer0415
11
Oct 24, 2015 08:16 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
black00chev
16
Sep 15, 2015 05:40 AM
