TIME SLIP DATABASE
10 sec pass today
Old 12-08-2008, 08:23 PM
  #21
quicksilverado's Avatar
Originally Posted by BigKID
Congrats Dave! You hit the 10's before I did you son-of-a-gun. Once I get this trans rebuilt, I am commin' for ya!
btw... what did you have your heads torqued to? I torqued my studs to 90ftlbs with moly lube and haven't had a problem so far with 10# on MLS gaskets, 9.7:1 CR and 19* of timing. I am sure you will get everything sorted out soon though.
Thanks Kenny. That pass was at 12 degrees of timing. We added 5 more degrees and it dropped from a 6.97 1/8 to a 6.84 1/8. It has about 2/10 left in it at that boost according to 1/8 mile et and the calculators.
The heads were torqued to whatever the specs are. I can't remember them though. The heads have been milled twice to even them out. We suspect the decks were just to thin. I have a set of All Pros waitng to go on the engine. They would have been on the truck already, but the truck was running so good, I hated to mess with it. Can't wait to see how you do when you get the tranny in it.
Old 12-09-2008, 09:26 AM
  #22
9 Second Club
cablebandit's Avatar
why havent you posted the vid?
sd/hd=standard/high definition
http://mssftw.com/videos/SD-Quicksilverado-10-93.wmv
http://mssftw.com/videos/HD-quicksilverado-10-93.wmv
oh i see you posted sd link already...HD link is posted as well now for those with a fast pc
Old 12-09-2008, 09:36 AM
  #23
BigKID's Avatar
That makes sense. ARP specs are 75ftlb with moly, 90 w/oil. I read were alot of high boost guys were torquing to 90 w/moly to give more clamping force so that is what I did. You may want to do that too when you install the AllPros. BTW.. let me know how you like those heads. I am considering them or AFRs for when I replace these ported 241s.
Old 12-09-2008, 12:26 PM
  #24
Bad_Apple's Avatar
Really nice times David where did you make the passes at Reynolds?? My computer want play the vidoes for some reason.
Old 12-09-2008, 12:35 PM
  #25
9 Second Club
right click and "save as"
Passes were at Steele
Old 12-09-2008, 03:36 PM
  #26
ZO6Ted's Avatar
Great passes Quick! I sure do like your truck and your setup.
Old 12-09-2008, 05:12 PM
  #27
LMSeven's Avatar
Nice!!
Old 12-14-2008, 10:05 AM
  #28
Got the heads off thursday. The head took the worst abuse. It can be repaired though. The steel liner is fine. The aluminum block was torched a little. It can be fixed without pulling the engine though. The All Pro heads will go on next, Truck should be up and running by the end of the week.
Old 12-22-2008, 01:34 AM
  #29
454SuperSport's Avatar
good job on the 10's man! i need to start keeping an eye out for these track days, would be nice to see some of your trucks run
Old 12-22-2008, 04:26 PM
  #30
chevrolet all the way's Avatar
i never did say it but congrats buddy! it was great meeting all of you guys too! hope to be invited next time too!
Quick Reply: 10 sec pass today
