TIME SLIP DATABASE
10 sec pass today
Old Dec 8, 2008 | 08:23 PM
  #21
quicksilverado's Avatar
Originally Posted by BigKID
Congrats Dave! You hit the 10's before I did you son-of-a-gun. Once I get this trans rebuilt, I am commin' for ya!
btw... what did you have your heads torqued to? I torqued my studs to 90ftlbs with moly lube and haven't had a problem so far with 10# on MLS gaskets, 9.7:1 CR and 19* of timing. I am sure you will get everything sorted out soon though.
Thanks Kenny. That pass was at 12 degrees of timing. We added 5 more degrees and it dropped from a 6.97 1/8 to a 6.84 1/8. It has about 2/10 left in it at that boost according to 1/8 mile et and the calculators.
The heads were torqued to whatever the specs are. I can't remember them though. The heads have been milled twice to even them out. We suspect the decks were just to thin. I have a set of All Pros waitng to go on the engine. They would have been on the truck already, but the truck was running so good, I hated to mess with it. Can't wait to see how you do when you get the tranny in it.
Old Dec 9, 2008 | 09:26 AM
  #22
cablebandit's Avatar
9 Second Club
why havent you posted the vid?
sd/hd=standard/high definition
http://mssftw.com/videos/SD-Quicksilverado-10-93.wmv
http://mssftw.com/videos/HD-quicksilverado-10-93.wmv
oh i see you posted sd link already...HD link is posted as well now for those with a fast pc
Old Dec 9, 2008 | 09:36 AM
  #23
BigKID's Avatar
That makes sense. ARP specs are 75ftlb with moly, 90 w/oil. I read were alot of high boost guys were torquing to 90 w/moly to give more clamping force so that is what I did. You may want to do that too when you install the AllPros. BTW.. let me know how you like those heads. I am considering them or AFRs for when I replace these ported 241s.
Old Dec 9, 2008 | 12:26 PM
  #24
Bad_Apple's Avatar
Really nice times David where did you make the passes at Reynolds?? My computer want play the vidoes for some reason.
Old Dec 9, 2008 | 12:35 PM
  #25
9 Second Club
right click and "save as"
Passes were at Steele
Old Dec 9, 2008 | 03:36 PM
  #26
ZO6Ted's Avatar
Great passes Quick! I sure do like your truck and your setup.
Old Dec 9, 2008 | 05:12 PM
  #27
LMSeven's Avatar
Nice!!
Old Dec 14, 2008 | 10:05 AM
  #28
Got the heads off thursday. The head took the worst abuse. It can be repaired though. The steel liner is fine. The aluminum block was torched a little. It can be fixed without pulling the engine though. The All Pro heads will go on next, Truck should be up and running by the end of the week.
Old Dec 22, 2008 | 01:34 AM
  #29
454SuperSport's Avatar
good job on the 10's man! i need to start keeping an eye out for these track days, would be nice to see some of your trucks run
Old Dec 22, 2008 | 04:26 PM
  #30
chevrolet all the way's Avatar
i never did say it but congrats buddy! it was great meeting all of you guys too! hope to be invited next time too!
