Dodge Engine & Exhaust Performance All EFI, Hemi, Magnum, 4.7, 5.9
WTF is going on with these trannys
Old Feb 3, 2007 | 05:23 PM
eabigrick's Avatar
Default WTF is going on with these trannys
i got 60,000 miles out of my stock tranny and that was with about 15,000 with the motor work and a little over 10,000 with a edge converter. in the last 4 months i have been through 4 transmisions. the first three were all stock with the stall and the last was built by one of the best tranny guys in the area. it was built with koleen steels and clutchs, that whole little transgo kit. it lasted two days and the clutchs are fried in that one two. is it posible to build a unit to last or do i need to burn this mf'r to the ground
Old Feb 3, 2007 | 05:27 PM
nightrunner's Avatar
Mr. Obvious
get a FLT and be done with it(they give you a warranty)
Old Feb 3, 2007 | 05:32 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Yup, throwing good $ after bad $ sucks.
I second the FLT trans. I push mine to it's limits and it hasn't let me down!
Old Feb 3, 2007 | 06:02 PM
blake2kz71's Avatar
damn what kinda numbers are you throwin through them? surely you have a trans cooler. i would say that the trans wasnt built right if you only went through 1 but 4?? could be heat, tune, converter, the builder, etc.
Old Feb 4, 2007 | 01:39 PM
Toe's Avatar
Toe
http://dodgetruckworld.tenmagazines....os=1&id=247623
Check out this link. These guys are trying to figure out the tranny as well. It's just not doing well to push more then 400rwhp through it, though these guys are trying to do double.
The problem in short is when downshifting from 4th, it drops into the other 2nd gear (we have two second gears in these trannies and 2 overdrives) but uses one of the overdrive clutch plates which are very weak. They've tried adding additional plates to those overdrive gears but they are running out of room in the tranny.
They are saying if you want to race from a roll, turn over drive off, that will drop you to 3rd, which has stronger clutch plates. You can then drop into second gear from 3rd, because it will use the upshifting 2nd gear which is stronger.
What we really need is, just like the pcm, we need to crack the tranny computer and find a way to program it different so we don't use the weaker plates. It's been said they can reflash our tranny to turn it into a true 7 speed... but Chrysler won't give us the codes to do so.
Old Feb 4, 2007 | 02:21 PM
Motorider228's Avatar
Well Toe hit it on the head. To save your tranny NEVER hit WOT in overdrive or from highway speeds. Also, FLT does not make a transmission for our hemis but suncoast does. They make a bulletproof 518 that mates right up to the hemi which is warrantied and can handle more power then you will probably ever have. There are also a few guys working right now to make our transmissions stronger with some new experimental parts.
Old Feb 4, 2007 | 02:29 PM
blake2kz71's Avatar
i didnt realize it was a dodge we were talking about. i dont know anything about them.
Old Feb 4, 2007 | 04:14 PM
Well he never said what it was but I assume it's a 45RFE or 545RFE as this is in the dodge section.
Old Feb 4, 2007 | 04:38 PM
Toe's Avatar
Toe
It's the 545 from what I remember in the other posts.
the suncoast conversion sounds interesting, I really wish I had some coin to play. One of those stroked 370 or 392's and a suncoast conversion tranny would be sweet.
Any idea what they are asking for it, how it works, and how they get around the tranny computer, 03's vs 04+?
Old Feb 4, 2007 | 07:50 PM
MrDestinE's Avatar
yea, tis a bitch with these trannys.... most of my fun is on the Hiway and since rollon downshifting is taboo, gonna have to give all that up....
TJ
