New 5.7l in the old ram.
How was the 400 built? It sounds like you added headers, intake and performer carb to a smog era engine. Even a mildly built 440 should produce over 400hp (decent cam and compression ratio plus what you have listed above). I had a 440 in a 4600lb Monaco that would run 14's, a reg cab truck doesn't weigh all that much more. Hell, my 03 quad cab is only 5300lbs.
I had a 78 smog era 440 with all the bolt-on goodies, but even with the parts I put on it, it really didn't help with the factory cam. It may of had 260hp TOPS, but it felt like 350TQ for sure.
I started the truck yesterday and again today, I still need to mount the wiring harness, hook up the 02 sensors, and a few other small things, I mainly wanted to start it before I routed the harness just to make sure it works.
Correct, the truck now has a 346cu.in. LS1. It origanally had a 318 ran a 19.3...slow, after 220,xxx miles swapped in a 440 with full bolt-ons, ran a 15.7 @ 84...much better, but most chevy 5.3 trucks run that with bolt-ons.
Truck sat for most of the time due to 7-9mpgs being easy on it. I bought a camaro, ran 13.5 stock with the ls1, every time I puty a part on the car it went faster, 11.5 with mild heads cam and stall. Now the camaro runs a 10.6 with a ls2 and a bigger cam 3600 stall and will still get 22 on the highway, something the 440 could never do, so out with it and in with the ls1.
FlowmasterMufflers
Sep 18, 2015 02:31 PM
sauldgold
Jul 23, 2015 02:15 PM
