Need Help Installing Headers!!!!!!!
Got a set of Longtube headers, and y-pipe coming, but I am stationed at Fort Gordon(Augusta, GA), and have no clue how to install them, is there any local that could do this for me? hopefully there is and we can talk compensation and whatnot thanx in advance-Airborne!
Soak the bolts in PB blaster a few times, especially overnight, to help the bolts come off without breaking. You will likely need a friend to lend a hand, it will make it ten times easier. Not hard, just awkward and frustrating at times (if you didn't have a lift to use like me). Take your time, should take 5-6 hours, maybe 4 if you hurry.
Do a search on this forum and Gm fullsize, you should turn up a couple of install threads. If you run into a problem, post up here and someone will help you out.
Best of luck!
Best of luck!
Access to a lift would help a ton. Make sure and remove both the front wheelwell liners and rims/tires and you actually have plenty of room to work. Soaking the bolts helps, however I don't remember it being an issue. Don't use the paper Pacesetter gaskets that come with the headers, opt for the Mopar ones, superior quality no doubt. I know on mine my buddy and I had to cut the transmission dust cover for the passenger side header to clear, only about an inch or so. Covered it up with a piece of steel and some red RTV silicon to keep the dust out, lol. Its really not that hard to be honest. Keep us posted and good luck. Once you get the headers on the y-pipe is a piece of cake, just clamp it in place and plug in your upstream/downstream o2 sensors, head over to your favorite exhaust shop and get it all buttoned up!
zblee
63
Jun 10, 2023 01:25 PM
zblee
Aug 3, 2015 03:45 AM
sauldgold
Jul 23, 2015 02:15 PM
