Lifted Hemi Quad Cabs
I am thinking about purchasing an 03' or 04' Hemi quad Cab. When I get a truck, I will be lifting it, and I'd like to see any pictures or what a lifted Ram looks like. Also, what lift, or exhaust, or wheels and tires combo do you recomend. Thanks a lot.
I don't know much about lift kits so I can't comment. I would think tires and wheels would be what looks good to you. Now the exhaust I may be able to help. The stock exhaust on the Hemi Rams is pretty darn good! The 03's sound real good and are louder compared to the 04-05's. If you all you want is more noise then again, it's a personal preferance. Alot of guys are running Magnaflows, Aeroturbines and Flowmasters. I would keep the stock tailpipe, it's a 3" mandrel bent pipe and it's stainless, just like the cat-back system companies advertise. If you want the dual pipe look, stay with 2.25" tailpipes so you don't loose low end torque, with a lift and bigger tires, you'll need all the low end you can get. Again, if you want more noise, listen to trucks and found out what they're running. If you want an all around good system, stay stock.
Jim
Jim
You might want to check out www.dodgetruckworld.com there are alot of lifted 2x4 and 4x4 ram on that site!!!!!
