Dodge Engine & Exhaust Performance All EFI, Hemi, Magnum, 4.7, 5.9
Jet Hot Coated Dynatech Headers On Sale!!!
Old Mar 12, 2006 | 06:26 PM
tbyrne's Avatar
Default Jet Hot Coated Dynatech Headers On Sale!!!
We're received alot of requests for our Jet Hot coated header special so we've brought this back until Sunday, March 26th! You can add Jet Hot coating to any set of Dynatech long tube headers for only $149.99! This will save you $100.00 off of the regular price! Most of the header prices on our website already have a built in discount to save you money off of the manufacturer's retail so this is like receiving a double discount!
The Dynatech header package is complete with everything you need for a bolt-on install (no cutting/welding required). You will receive the long tube headers along with highflow cats and Y-pipe. All of the bolts and gaskets are also included. You can expect about a 25hp increase with this package. Pictures and more info can be seen in the Truck Exhaust section of our website.
If you would like to order the header package without coating we can offer you free shipping for orders being delivered in the 48 states.
JET-HOT® develops, produces and applies a variety of coatings. Properties of the various coatings include insulation, corrosion resistance, abrasion and impact resistance as well as lubricity. All are applied through a meticulous, multi-step process including: thermal degreasing, abrasive-blast stripping with virgin aluminum oxide, double-coating (inside and out on headers), high temperature curing, custom packaging for return shipping, and quality-assurance controls during every phase of the procedure.:
JET-HOT 1300™ - Jet Hot's exclusive formula works beautifully on new or used parts at temperatures up to 1,300°F. Sterling™ is the most popular finish. This high-luster coating, containing silver powder, shares the brilliance of chrome with the subtlety of nickel. It provides the most brilliant appearance in high-temp, high-tech coatings while delivering major performance advantages. Sterling™ is also an extremely easy coating to keep clean. The same basic formula is available in matte black, blue and cast-iron gray.
Horsepower gains depend on many variables, including engine size, type and setup; cooling system performance; ambient temperatures; and other factors.
Nevertheless, JET-HOT Sterling will normally boost power when applied to headers for two reasons. First, the coating promotes denser, more potent fuel/air charges by insulating the engine bay from exhaust heat. At the same time, it accelerates the pulsed-vacuum effect on “tuned” headers, resulting in more effective scavenging of cylinders. The increased velocity of exhaust gases produced by higher exit inertia not only clears each cylinder more quickly; it also draws in the next fuel/air charge more efficiently.
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763).
Have a good day!
zblee
63
Jun 10, 2023 01:25 PM
Corvette454l88
Sep 1, 2016 01:24 AM
Stainless Works
Aug 7, 2015 10:08 AM
steves86ta
Jul 28, 2015 10:21 AM
blownss27
Jul 20, 2015 08:59 AM
