Dodge Engine & Exhaust Performance All EFI, Hemi, Magnum, 4.7, 5.9
i nees some help
Old Feb 21, 2007 | 01:41 PM
yourugly_ihateyou's Avatar
Default i need some help
hey can someone help me put a cold air intake on my 03 dodge ram
Old Feb 22, 2007 | 01:22 AM
06hemi's Avatar
where you live at boss
Old Feb 22, 2007 | 02:15 AM
Toe's Avatar
Toe
They are all pretty easy to do, even for a computer geek like myself. I put an afe intake on mine, took about an hour first time through, and much faster after that. Just pull the stock airhat/box off, should be a couple bolts holding it all in there, and drop the new one in. You might need to loosin up a couple of bolts around the rad to hook up the new one too. Make sure you got a good fit around the throttle body, and make sure you put the iat sensor in it's new location. You'll need you standard socket set, forget if you need a metric one or not, and a couple screw drivers.
Each intake is gonna be different, just take your time and there should be no problems.
Here's mine, dirty engine bay.
Mark Johnson
Oct 17, 2014 08:59 AM
HAMMER!
Jan 7, 2013 03:08 PM
06colorado
Aug 14, 2012 11:29 PM
noWThere
14
Apr 16, 2012 07:30 AM
