Dodge Engine & Exhaust Performance All EFI, Hemi, Magnum, 4.7, 5.9
any potential with a 4.7?
Old Jul 4, 2005 | 04:48 PM
Default any potential with a 4.7?
How's it going guys? I have a 00 dakota and i love the body style of it, but the motor leaves a little to be desired. I know the 4.8/5.3 of the chevy's have a ton of potential but i don't want to give up the dakota body. Anyways, what kind of modifications does the 4.7 respond to well? I know that everything responds well to a supercharger, but what else can i do to the 4.7 to get her moving. On a side note, is it just me or does it seem like every 98+ dakota ever made has a has a tranny go out between 100 and 125,000 miles.
Thanks for any replies,
trav
Old Jul 4, 2005 | 05:50 PM
juice it!!!!!!!!
Old Jul 4, 2005 | 08:25 PM
i understand that nitrous is the best bang for the buck but i want a real modification, something that gives me power all the time. Obviously i am not looking for something as fast as my camaro, but i want a spunky daily driver. Is a cams swap an option for the 4.7, or heads or intake. Or should i just skip all the bs and supercharge it.
any thoughts would be greatly appreciated..
trav
Old Jul 4, 2005 | 10:14 PM
Jrgnd's Avatar
I see Kennebell in your future.
Old Jul 5, 2005 | 07:56 AM
bad360rt's Avatar
11 Second Truck Club
There are a few choices for cams now for the 4.7's and you can do the HO intake. A few people have gone with blowers, I hear tuning is a lil tough. A guy in Arizona did his own turbo setup and has run low 12's at 3500+ft in the heat. The aftermarket just never really picked up for the 4.7's. But some cams, intake, tb and exhaust and you should see some nice gains. KRC has 4.7 cams:
http://www.krcperformance.com/newcontent/cams.html
Old Jul 5, 2005 | 10:35 AM
Outlaw Kasten's Avatar
spray, HO cams, and gears
Old Jul 6, 2005 | 01:23 AM
C.T.D.'s Avatar
Put a 12Valve Cummins in it!!!!!! well depending on the money you are willing to spend, turbo that thing!! i think it would be different, i havent really seen a turboed Dak, (havent really looked lol) but i think it would be awesome, but money wise a kennebell or spray
Old Jul 6, 2005 | 09:12 AM
If i were to do anything, i would prolly go with the HO cams, ported intake and throttle body matched with some headers and a custom tune. Now for another very important piece of the puzzle, how well with the tranny and transfer case hold up to the added power? My truck is a one wheel wonder right now and i can guarantee you she wouldn't stand a chance of hooking up even if i put a posi unit in it, so i am probably gonna have to launch in 4 wheel hi. I have a friend with a 00' 4.8 4x4 silverado with a cam and a 2600 stall and 4.10's, and he can launch that thing pretty friggin hard in 4 wheel drive. It's pretty safe to say that nothing will stand a chance 0-30mph against that thing. He smokes my camaro right off the line until i hook up and get moving again. Anways, he has a 4l60e tranny and surprise surprise, it's slipping really badly on him. How well is mine gonna hold up?
I just want a fun daily driver, i only get 17mpg right now anyways, and if after doing all this work i am down to 12-13mpg i am willing to make that sacrifice cuz i will be having alot more fun!
One more question, how good is the rotating assembly of the 4.7? I have 90,000 miles, is that gonna be an issue?
thanks guys!
trav
Old Jul 6, 2005 | 09:21 PM
MadDuner's Avatar
I'd go with the HO cams if you're gonna try and pull all that weight around. To realize the potential of the 4.7 engine will take some re-programming of the PCM... 4.7's NEED ignition timing. Go with a 70mm F&B throttle body, CAI and some free flowing exhaust and you'll be making some decent power. If you don't mind sacrificing some low-end torque you can go with larger cams. No matter what you do - you will need to make it pull both rear tires. If you go with more aggressive cams you should probably go with a set of gears also.
The 4.7s do in fact have some potential....
http://members.***.net/duner/Turbo/DunervsLethal.wmv
Old Jul 6, 2005 | 10:40 PM
waltherone's Avatar
You might save a little cash on the headers, not a lot of people have been incredibly happy with them... it's not so much that they're bad, it's just the price vs. value doesn't add up, they're a bit overpriced for the little that they do on an N/A 4.7 it seems.
The KRC 206 cams are what I've got in this truck, they've still got a really low powerband, nothing like a big all motor cam where you've got no bottom end.. they're probly a good choice, but again there's the price vs. value, you can do the HO cams for a couple hundred bucks, these 206 cams were 499 dollars when I bought them, they're 750 now, that's a lot for a set of cams..
PCM flash is a MUST like duner said... just simply a MUST... if you try to argue, you are wrong. Say it with me... a MUST
