Dodge Engine & Exhaust Performance All EFI, Hemi, Magnum, 4.7, 5.9
5.2L its cranking but its not firing... WTF IS THIS?
Old Dec 5, 2005 | 02:27 PM
Default 5.2L its cranking but its not firing... WTF IS THIS?
okay so my friend and i just got home- and we were gonna go get some lunch- but when he went to start the durango and its cranking over but its not firing- does anyone know wtf could be happening? We took the positive side off so the ECU can reset but we dont know what to do next. Thanks
Old Dec 5, 2005 | 03:36 PM
HELP-------------------------------------------------- PLEASE------------ We recrimped the spark plug wires and made sure that they are on there tight- we can smell the fuel........ we reset the ECU, and now wtf do we do- could it be the distributer?
Old Dec 27, 2005 | 12:58 PM
Ledman_70's Avatar
Default No fire
My 99 Dakota R/T started running rough and not starting last summer. My friend, a mechanic, hooked a scanner to it and determined it had a bad cam position sensor (the plate in the distributor). Replaced it, about $45 and the problem went away. You may check that out.
Ledman_70
Old Dec 27, 2005 | 09:21 PM
MrDestinE's Avatar
These days you just HAVE to have a scanner to do anything at all..
good luck
TJ
Old Dec 28, 2005 | 07:07 PM
ktmrider's Avatar
good luck
TJ
Unfortunately this is very true. For reference I had a Dakota that would not start in very cold weather. Turned out to be a bushing in the distributor that shrank and shorted out the spark signal. It had the same symptoms as your buddy. I had to take it to the stealership to get it checked out. No other way these days
Old Dec 29, 2005 | 10:56 PM
12 Second Club
Ok first you need to determan if it is spark related. have your buddy crank while you hold the plug wire near the plug see if spark. if it is then you know its fuel if no spark them out comes the scanner.. what year is the dodge? cause if you dont have a scanner you can ground out the #1 term in the data port and it will flash a code at you, or if new enough, turn the ignition on and off 3 time it will display the code were the odometer would be.
could be something as easy as a ASD relay (check power at that) or just switch it with the a/c relay they r the same in most cases.
if your in minnesota i could help ya out im a tech at a chrysler dealership but anyway good luck
RustyD
May 23, 2016 07:04 PM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
trxmxzx
Sep 29, 2015 07:42 AM
