help with bleeding pump
Old Dec 23, 2009 | 11:34 PM
waltsfastz's Avatar
11 Second Club
Default help with bleeding pump
long story short. I replaced the lift pump. Bled the pump. i have fuel to 4 of the 6 injectors whre it goes in the head. It will crank and hit for just a second and then go back to cranking. Letit sit a few minutes and it will do the same. Any sugestions?
Old Dec 23, 2009 | 11:51 PM
viciousknid's Avatar
Where's the Beef?
Have you tried tampons?
jfwy. Honestly curious to know incase it will help me with an issue my dad is having as I have no idea whats going on.
Old Jan 3, 2010 | 05:29 PM
01HO's Avatar
Registered User
I assume this is a VP truck? Need some info first.
Did you replace factory lift pump with another factory pump?
What was the reason for replacing(quit one day, low pressure, hard start, etc)
I have seen trucks do this when there is alot of air in the system, it will bleed out and start but takes a little time.
Old May 29, 2010 | 11:37 PM
BigRed Cummins's Avatar
Which pump is it? If its a VP (1998.5-2002 24 valve) then if the lift pump went bad, then the injection pump is most likely toast. They are fuel lubricated and usually take a poo when the lift pump does. Do a google search for VP pump failure for more details. If it is a P-pump (1994+ 12 valve) Then you need to just bleed the ever-loving crap out of the injection lines. It can take a while to get all the air out.
$A_Money$81
Mar 27, 2023 10:25 AM
Chavette
Oct 28, 2015 07:33 PM
turbo6c3
Oct 5, 2015 06:11 PM
sTNT971
Sep 26, 2015 04:22 PM
rednekferlife101
Sep 14, 2015 05:27 PM
