truck keep running after ignition is turned off..
Old Sep 4, 2011 | 05:33 PM
06murder's Avatar
Default truck keep running after ignition is turned off..
like the title saids....my carb 5.3 keeps running after the ignition is off,only when she is warmed up...could it be that the carb idle is to high, or something with the carb, if i have the choke pluged up it it does it longer then it does with the choke plug up....any ideas
i has an 650 cfm holley carb, eldbrock timing module
Old Sep 4, 2011 | 05:54 PM
6789olds's Avatar
idle too high , too much timeing , octane is to low. Is it pinging? has it always done it or just started ?
Old Sep 4, 2011 | 06:02 PM
06murder's Avatar
i just got her up and running last weekend....it does idle pretty high,coulnt tell you how hi cause the tach isnt pluged up yet
Old Sep 4, 2011 | 06:03 PM
06murder's Avatar
could i put some ocrane booster in it?
Old Sep 4, 2011 | 09:44 PM
retorq's Avatar
Octane booster won't fix a carb that isn't adjusted properly.
Old Sep 5, 2011 | 12:27 PM
06murder's Avatar
i adjusted the idle n put more fuel to the carb, an it stop dieseling....she over heating a bit...i fixed the bypass for the heater core on the water pump,just loop it to the other end,cuase im not running an a/c or anything i took all of it out...but she will get to 200-210 for a few mins then start going up to like 240,but slowy gets there, i dont think i blew a head gasket cause there no blue smoke or anything from the exhaust,well i dont c any,but i do have an exhaust leak,and its like a blue grey though..any ideas
Old Sep 5, 2011 | 01:52 PM
retorq's Avatar
I'm no expert on the newer cooling systems but if it's not routed right you will have air pockets caused by hot spots and it will do exactly what you are describing. I went thru that with my Vortec head swapped OBS Tahoe ... was a pain in the *** to track down and get right.
Old Sep 5, 2011 | 01:59 PM
06murder's Avatar
what did you do to get it right, would that dex-cool antifreeze matter? cuz im use o'reilly brand
Old Sep 5, 2011 | 03:47 PM
DR132's Avatar
the brand and color of coolant shouldn't make a difference...does the temperature drop back down to around 190-210 after it gets up to 240 or does it stay high?
Old Sep 5, 2011 | 04:38 PM
06murder's Avatar
it stay at 240 ,is it cause i dont have a fan shoud?
