rear end
My 84 c10 rear end 10bolt is all stock non posi. I just had a 5.3 put in. Wuts the cheapest way to get posi (locker, spool, etc..). I just need this to hold me off for 3months till I order a 12bolt from currie. Also what gears would be ideal for highway yet still good for take off. This is my dd.
as for the gears what size tire and what tranny u have? it will help pick the gear to suit u better. to be honest no need for u to buy a curruie diff save your cash. the 10bolt 8.5" will take the abuse if its set up right, hell seen turbo trucks and big block trucks run them with no problems. plus this is your dd your running steet tires not slicks. i would just get a tru trac the spool will keep the tire locked all times dont want that for a dd.
with your 30" tire and your 700r4 gearing, with 3.73s youll be spinning about 1900rpm at 65mph, and with 4.10s youl be at 2100rpm 65mph. i would go for the 4.10 but you have to decide what rpms you want to be at.
TimDave217
Aug 24, 2015 04:38 PM
shupe
Aug 5, 2015 06:45 PM
