No Spark?!?!?
Old Dec 7, 2011 | 09:06 AM
reiners88's Avatar
Tiny hole? Can you get a pic of it?
Old Dec 7, 2011 | 04:37 PM
C-10Chance's Avatar
Yeah, ill post up a pic in a min
Old Dec 7, 2011 | 04:43 PM
C-10Chance's Avatar
Btw, i let it sit overnight after i put that cap on, because it wouldnt start up after i put it on. And it started right up..
This thing is aggravating
Edit: Well i drove it to my cousins house about a street over and let it sit for about an hour and half. And now its not starting...
Old Dec 9, 2011 | 08:55 AM
Stainless Works's Avatar
FormerVendor
The hole appears to be used for the wire holder which mounts on top of the coil, do you have the same hole on the other side of the cap??
You may have a bad module, take it out and have it tested at the local auto parts store.
Old Dec 12, 2011 | 02:34 PM
C-10Chance's Avatar
So can they test the coil on top of the cap??
Old Dec 12, 2011 | 08:11 PM
reiners88's Avatar
It is starting to sound like the module inside is taking a crap. Had it happen on my old truck. Didn't do exactly what yours is doing but similar
Old Dec 12, 2011 | 09:29 PM
retorq's Avatar
I'm late to the party here but I had a similar issue and my cause was the button between the coil and the cap. One time that rubber insulator got tore up some thing fierce somehow, sometimes it ran sometimes it didn't ... I've also worn that button down to the point that it didn't run ... might be worth looking at.
Old Dec 13, 2011 | 02:20 PM
FormerVendor
You can test the coil by doing an ohms test, check google for how to. the carbon brush and rubber bushing can wear out causing the same issue. May just need a good tune-up!
Old Jan 2, 2012 | 06:16 AM
C-10Chance's Avatar
Well I still cant get the truck to start. New reman distributor, new hei coil, and new rotor. Still not firing up. Check all the wires. They are all good. But one thing is its not getting the full 12V when cranking the motor. Has 12V when the key is on but only about 8.2V when cranking it. Whats the deal???
Old Jan 2, 2012 | 06:18 AM
C-10Chance's Avatar
Well shouldnt you be able to push the button with the cap off and coil still attached? Because mine is stiff. Not sure if its suppose to be like that?
SlvrSierra4.8
Oct 1, 2015 09:39 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
cousblake11
Sep 9, 2015 06:52 PM
smokeshow
Aug 23, 2015 08:23 PM
