Leaking truck
Old Aug 23, 2010 | 02:48 PM
1991Chevy's Avatar
Exclamation Leaking truck
So I have a 1991 Chevy like the name says. I just recently came upon this problem when driving it this Sunday. Truck Check Gages came on I looked seemed like the motor wanted to over heat so. Being smart I put water in the radiator until I could get it checked out. SO this morning same thing is happening expect that this time I noticed water coming from the bottom radiator I think water pump? What do yo guys think?
Old Aug 23, 2010 | 02:55 PM
black04's Avatar
Yeah check the water pump. It has a little wheep hole on the bottom of it and if its bad then it will leak from the wheep hole.
Old Aug 23, 2010 | 03:05 PM
SILVERBIRCH's Avatar
double check under it again and check if it leaks from the front and back of the motor I had the same problem on my 99 tahoe and it was the very common intake manifold gaskets problem if thats the problem use the fel-pro gaskets to fix it up good luck.
Old Aug 24, 2010 | 12:24 AM
1991Chevy's Avatar
Thanks for the tips. I won't be able to get under the hood again until Wednesday so I will keep you guys updated.
wrb002
Aug 31, 2015 12:00 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
1320Chicken
Jul 14, 2015 10:58 PM
Mzay
Jul 6, 2015 11:03 PM
