Leaking truck
So I have a 1991 Chevy like the name says. I just recently came upon this problem when driving it this Sunday. Truck Check Gages came on I looked seemed like the motor wanted to over heat so. Being smart I put water in the radiator until I could get it checked out. SO this morning same thing is happening expect that this time I noticed water coming from the bottom radiator I think water pump? What do yo guys think?
double check under it again and check if it leaks from the front and back of the motor I had the same problem on my 99 tahoe and it was the very common intake manifold gaskets problem if thats the problem use the fel-pro gaskets to fix it up good luck.
Mossyoakglock
Jul 17, 2015 08:30 AM
