got an question
Old Apr 24, 2011 | 08:37 PM
06murder's Avatar
Default got an question
i have an question....im putting a 5.3 in my 91 silverado,do i have to take the tranny out first be4 the motor will go in or what....first time puting an motor in n i have no help so yeah...
Old Apr 25, 2011 | 08:15 AM
Is the trans your using going to bolt up? If it will you should be able to leave it in. If you have to take it out you will have to block the motor up in the back so it doesn't sag on the mounts to much. hope this helps. Also check and make sure that your flexplate is going to work with your torque converter.
Old Apr 25, 2011 | 08:29 PM
06murder's Avatar
my 350 was already out it was pushed forward a good bit so i went ahead n took it out,its a 700r4 soon to be th350 i heard the flexplate kit on summit would work with the th350 torque converter ...but anyways i got the motor in after a lil wiggling it in man that was and work out n i dont weight much from the start with mayb 120 or so but its in
Old Apr 25, 2011 | 08:38 PM
Swerve7rpm2000's Avatar
Trying doing it with a 6.0 and 4l80e in our trucks!! I beat everything up, ended up seperating and installing individually
Old Apr 25, 2011 | 08:43 PM
06murder's Avatar
r u running carb man?
Old Apr 25, 2011 | 08:49 PM
nope all gm fuel injection, click the link on the bottom of my signiture
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
