Converting a 1990 Chevy 1/2 ton Instrument cluster to a 1993
Old Jul 9, 2007 | 03:49 PM
cessna206's Avatar
Registered User
Default Converting a 1990 Chevy 1/2 ton Instrument cluster to a 1993
A guy on E-Bay says that there is a wiring conversion for installing a 1993 Instrument cluster into a 1990 Chevy truck (I hate that cluster) and when I asked for it he said it could be found on the net. So far Im in Dire Straits. Can anyone help?
Old Jul 13, 2007 | 07:30 PM
BayouSS's Avatar
Check on Full Size Chevy and 454SS.com you'll find help there.
Old Aug 13, 2007 | 06:29 PM
YenkoST's Avatar
They have a write up on Fullsizechevy.com.
Old Feb 29, 2008 | 08:29 AM
SixSpeedSS's Avatar
You want to get a 1991 cluster, because it has the same type of connector as the 1990. The 1993 truck's connector is reversed (male instead of female or vice versa - it's been awhile since I looked at it). If you use the 1993 style cluster, you will have to cut the harness from a 1993 truck & solder it into your dash.
I had a 1990 4x4 & I just added the tach wire & plugged in a 1991 cluster. I think I had to move one or two wires also. It was a very simple swap.
5.3Okasai
Mar 9, 2022 01:07 PM
GRRR65GTO
Aug 17, 2015 11:33 PM
FlowmasterMufflers
Aug 14, 2015 12:47 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
350SS
Jul 11, 2015 12:34 PM
