94 K1500 L33 upgrade
Old May 4, 2011 | 11:07 PM
  #101
chevyrace47's Avatar
i also just read both the threads you have on the obs swaps and have a couple questions for now. did you have any issues with the oil filter clearances on the 4wd? and did you use the stock cruise control for either swap? im building a 6.0 for my 94 and you're threads are very helpful.
Old May 5, 2011 | 12:07 PM
  #102
bowtieguy79's Avatar
Glad your finding some value from my builds. No clearance issues at all for the oil filter, same amount of room in the 99 and up body style trucks. Both the 95& 94 are DBW, was able to just use the wires that went to the cruise control box from the cab, and splice those into the DBW box to achieve proper cruise control. I have yet to do this on the cable throttle LS in my 79. When I do, I have a 02 cruise box I will use.
Old May 5, 2011 | 12:37 PM
  #103
cttandy's Avatar
What would you charge to convert my truck if I brought it up to you?
I could supply the engine and trans.
Old May 8, 2011 | 08:50 PM
  #104
I'll be in Nashville for Hot Rod Power Tour, show up we'll chat
Old May 8, 2011 | 09:36 PM
  #105
cttandy's Avatar
When is that? Sorry, staying to busy at work to keep up with the power tour this year.
The guy wants $2,200 to build another TBI 350 for my suburban. I am thinking I would be better off converting it over to a 5.3\4l60e. I wont have the time to do it myself.
Old May 30, 2011 | 03:08 PM
  #106
1989k1500's Avatar
Could you elaborate on what wires you spliced to make the cruise work?
Old May 30, 2011 | 08:50 PM
  #107
I got all of my info from this site. This guy is good! he helped me out getting the correct schematics for my 94 swap a few times.
http://www.lt1swap.com/dbw.htm
Old May 30, 2011 | 09:19 PM
  #108
1989k1500's Avatar
Awesome, thank you sir!
Old Aug 24, 2011 | 08:59 PM
  #109
Just an FYI.... The LS swap in the 94 is running great! Best mod ever!
Old Sep 24, 2011 | 08:33 PM
  #110
the chev's Avatar
Registered User
i'm doing the same swap but into a 89 5 speed alot more work because of the 5 speed keep posting and post what you use like a stand alone harness headers or what i did a solid axle conversion swap on my 89 best decision i have made on that truck hoping a ls motor is an evan better decision
