92 c1500 sputtering problem. Please help!!
Old 03-23-2012, 04:14 PM
ryan_wagnon's Avatar
Default 92 c1500 sputtering problem. Please help!!
ok just put in a new fuel pump and fuel filter on my 92 c1500 with the 5.7 engine. If i floor it from a dead stop it will almost shut off at about 3 grand but then is will pick up again but then do it again at about 4.5. What could this be???? Thanks for all your help.. And there is no check engine lights on.
Old 03-23-2012, 04:55 PM
DR132's Avatar
run some sort of fuel treatment through it such as sea foam to begin with. also check your cap and rotor, there's a fair chance they are pretty fouled up. pull a spark plug or two while you're at it. your problem would likely be solved with a full tune up.
Old 03-23-2012, 05:36 PM
2000chevysilverado's Avatar
Wut he said above
Old 03-24-2012, 08:12 AM
ok im going to try that and we are also gonna try to do a fuel pressure test while driving it. Think maybe my new fuel pump is slaking at high rpm?
Old 03-25-2012, 04:32 PM
put a new distributor cap on today and rotor button still no diffrence!!! Lol this one is gonna drive me crazy. Im one of those people if something is wrong i need it right like right now lol.
Old 03-30-2012, 05:37 PM
retorq's Avatar
TBI?? Get a USB cable and scan it with a laptop to see what's going on realtime ...
Old 03-31-2012, 08:56 PM
DR132's Avatar
Any news?
Old 03-31-2012, 10:13 PM
chevymec's Avatar
Check for excessive up and down play in the dizzy shaft. Also the computers will lose ground and act up. You can pull the glove box and make a quick ground to the computer box to check that. Did you relace the rubber hose on the pump when you replaced it? They are known to split or swell and let fuel not pass through it.
Old 04-01-2012, 06:11 PM
put new fuel pump and rebuilt tbi and fuel pressure regulator. still nothing!!
Old 04-04-2012, 08:48 PM
retorq's Avatar
Throw more money at it!!
Quick Reply: 92 c1500 sputtering problem. Please help!!
