89 c1500 headlamp conversion
Old Feb 24, 2010 | 07:41 PM
Hofer Jr's Avatar
Registered User
Default 89 c1500 headlamp conversion
Hello, I`m not sure if this has been posted (unable to find a thread on it). I have a `89 c1500 with the 4 sealed beam headlights and I would like to put in the composite style . If I were to order a set of composite head light assemblies would I need to do any modifacations or build any mounting brackets or will they bolt in? Thank you in advance for the help
Old Feb 24, 2010 | 08:03 PM
caddy03pimpin's Avatar
They go is in the same location as stock and use the same hardware to mount. You might have to trim the back of the radiator support brace behind the headlight with some tin snips to allow the new housing to fit properly.
Old Feb 25, 2010 | 10:24 AM
Hofer Jr's Avatar
Registered User
Thank you for the reply, the pigtail for the lights should be a quick snip and attach the halogen sockets then eh?
Old Feb 25, 2010 | 11:05 AM
You do not even have to snip. The new ones come with a H10 halogen bulb and you just connect your factory harness to the back of the bulb and your finished
denalircsb
Dec 21, 2020 09:04 AM
Silver8ado
Sep 30, 2015 11:42 AM
spooneralmighty
Sep 11, 2015 02:28 PM
InsaneDomestics
Sep 10, 2015 05:32 AM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
