88-98 ls swap what mounts are you using?
Old Jul 22, 2012 | 04:33 PM
383sschevy's Avatar
Originally Posted by LS1FREEK
Trans-Dapt #4575, it says 1" back but with these I was able to reuse my stock driveshaft and the Schoenfeld long tube swap headers fit perfect without any fitment issuses
what year truck did you use these on for swap i have a 91 c1500 with th350 runnung schoenfeld longtubes wondering if i should use 1" back or regular?
Old Jul 23, 2012 | 12:34 PM
LS1FREEK's Avatar
13 Second Truck Club
This was on an 89 c1500 with a th350 tranny
Old Jul 24, 2012 | 06:42 AM
tb8125's Avatar
Dirty dingo
Old Jul 24, 2012 | 08:05 PM
iamkeniff's Avatar
Josh powers 3/8" thick with stock clam shell mounts
Old Jul 24, 2012 | 10:10 PM
chevyracer8262's Avatar
I built my own, I have a 93 k1500 with a 2001 5.3l/4l60e combo with custom program, 3" single exhaust, dynomax super turbo muffler, egr delete, dual electric fans, 3.73" gears 33x11.50" tires and I had to turn the traction control back on to keep it from eating the back tires... I've loved this swap ever since I did it, of yea I use it quite often towing vehicles on my car trailer and drive it almost 500 miles a week to and from work and avg just over 17mpgs hwy/15mgs city.... Here's a dwg of the mounts I built I had to use the 1" offset so the engine would sit back enough for the transmission to be in the proper location for the factory driveshafts to hook back up, oh yea get the y pipe and cats from the donor truck it'll bolt right in and clear everything. I used some scrap 1/4" thk 4"wide steel flatbar to make mine only took about an hr and a half to cut drill and tap and it set right in..
Old Jul 25, 2012 | 10:22 AM
foreverfalcon40's Avatar
Trans-Dapt Performance Products 4572 - Trans-Dapt Performance Engine Swap Motor Mounts - Overview - SummitRacing.com
I was going to get dingos...just don't like that they are adjustable when I feel it is not necessary.
More pics and vids PRO Tour hoe she is a work of art. When my swap is done I am entering the road race in Arnold, Nebraska!
Old Jul 25, 2012 | 05:07 PM
1989k1500's Avatar
Dirty Dingo here. Going to set them all the way back.
I modified mine to work with some Moroso solid frame pads.
Old Mar 5, 2014 | 08:11 PM
silvy13's Avatar
im starting a swap as well in a 96 Silverado I been looking at the trans dapt 4592 will these work as well
Old Feb 11, 2015 | 03:12 AM
J907's Avatar
Registered User
Looking at doing the same to my 88 Chevy k1500 4 wheal drive what mounts are people using to keep the transmission in the same spot so I can keep both my stock drivelines????? Do you use an inch back mount?
Old Feb 11, 2015 | 07:07 PM
akdg87's Avatar
yes one inch setback mounts, thats what i used in my 1993 k1500 blazer swap.
I bought the transdapt and reused the clamshells off the 350 in my swap.
