84c10 5.3 4l60e swap
Old Sep 15, 2010 | 09:00 AM
cdime's Avatar
Registered User
Default 84c10 5.3 4l60e swap
Hi i would like to introduce myself, my name is jason and i live in minnesota. i grew up with these trucks running around everywhere in the 80's and just got an itch to build one about a year ago. So i went on cl and found a clean 84 2wd shortbox with a rattle can or roller carolina blue paintjob. i was planning on just dropping it and driving it with the 350/t350 but i started sanding on the body and then it turned into buying a 99 5.3 and a new tranny...
so far i have installed a djm 3/4 kit, finished all my body work got it in ppg ncp 270 primer waiting to be blocked, sealed and shot. the motor and tranny are dropped, schoenfeld long tubes coated and ready to install, engine bay all cleaned and repainted (mullsane blue metallic) i have sound deadened the cab.
i have to pull the box to get the rear of the cab and install fuel lines, tranny cooler/lines, and hook the computer all up. i sent the cpu to jesse bubb and sent the harness to current performance.
early pic during body work-
front pic-
engine when i got it-
engine on stand after cleanup-
engine in truck-
all soundproofed up-
Old Sep 15, 2010 | 09:02 AM
cdime's Avatar
Registered User
i ended up removing all the glass during the body work phase and it is about done now. what i need help with is running fuel lines and transmission cooler lines...this an fitting stuff and adapting to factory lines vs running new and finding right fittings is making me go crazy?!! what have you all done,,,all i have figured out is the russell quick connects from summit.
i am running an external walbro 255 and am looking for a fuel filter for it.
i have the 99 so it has the regulator in the fuel rail.
Old Sep 15, 2010 | 09:33 AM
bowtieguy79's Avatar
Nice work so far! Hey did you make your own engine mounts? They look great.
Old Sep 15, 2010 | 10:52 AM
cdime's Avatar
Registered User
hey 79 i sent you an email this morning, regarding your an fittings..
they are the dirtydingo.com mounts for the ls truck
Old Sep 16, 2010 | 01:25 PM
cdime's Avatar
Registered User
79 thanks for the information!
Old Sep 16, 2010 | 01:31 PM
cdime's Avatar
Registered User
my other ls powered vehicle. bowties only
Old Sep 20, 2010 | 08:09 AM
cdime's Avatar
Registered User
put some earls adapter one the fuel lines and put the russell fuel line adapters on yesterday...i think i might cut back the return line and put a 90 on it.
Old Sep 21, 2010 | 09:16 PM
sweet! Looks familiar.... your welcome :-)
Old Sep 24, 2010 | 03:32 PM
softballnrd27's Avatar
What headers are you using? Did they require any trimming any where?
Old Sep 27, 2010 | 09:57 AM
cdime's Avatar
Registered User
ls1 truck shoenfelds..no trimming.
