6.0 into 86 Silverado
Old Sep 2, 2007 | 11:18 AM
chevyguy7802's Avatar
Id stick with the th350,its alot easier to spin than a 400..
Old Sep 2, 2007 | 11:29 AM
NegraRCSB2X4auto's Avatar
I think he's going to stick with a carb.
Old Sep 2, 2007 | 11:37 AM
truckmann's Avatar
I'd stick with the TH350 too unless you plan on putting over 500hp to the wheels. TH400 are stronger, but they are also power robbers.
Old Sep 2, 2007 | 09:08 PM
jons03's Avatar
Looking good. Do you plan on putting the inner fenderwells back on? I know they're huge. LOL
Old Sep 6, 2007 | 09:12 PM
team39763's Avatar
I might stick with the TH350. Either way I need a new trans. I'm hoping to put close to 400 to the wheels in this truck, and I'm also planning to spray a 150 shot. I think ya'll are right, I should keep the Th350. Na, I'm not putting the inner fenders back in, I like the way I can just jump in there from the top or slide in from the wheel well(lots of room). Who knows, I may end up having to put them back since this town is so dusty(lots of dirt roads). I most likely wouldn't drive it in the rain, so I'm not worried about water.
Old Sep 8, 2007 | 12:07 PM
team39763's Avatar
I finally got some headers, but they don't fit for ****. I should have just made some headers instead of trying to make these fit. The passenger side required a good bit of grinding on the crossmember mounts and along the frame. The driver side needed the lower control arm grinded a lot too. Then after all that grinding just to let them bolt on, I realized the driver side collector points into the frame and now I have to grind there and make some funky bend to connect to the X pipe. I think I can make them work as long as the motor doesn't torque over too much(I'm gonna run a torque limiter, so it shouldn't be a problem).
Here's a picture of the passenger side.
Old Sep 8, 2007 | 04:42 PM
Looks good man nice work! I think youll like the th350 better mine has been holding up great hot rodding it with and without the nitrous
Old Sep 8, 2007 | 09:15 PM
ThrottleHappy7's Avatar
It looks good and it's going to look good. Just keep the end in mind. I'm looking forward to seeing the final product.
Old Oct 11, 2007 | 01:45 PM
team39763's Avatar
Just a little update. I am almost ready to start it. I don't have the new trans/converter, so I can't drive it yet. I'm gonna try to get someone to help me wire it up this weekend. I just need the fuel pump/relay and the electric fans/relay, alternator, and the gauges wired up. I may just throw in a stock trans and converter just to run around for a bit until I get the new stuff.
Old Oct 15, 2007 | 02:47 PM
Can we say, FUN!
I'm sure the work hasn't all been fun, but I'm sure the end result will be worth it.
