1950 Chevrolet 6.0L Thriftmaster
Old Nov 14, 2007 | 01:19 PM
  #21
OnyxSilveradoSS's Avatar
Originally Posted by wyldwest
Detroit 3100 any idea on after market harness and re flashing the computer, and do you need the pressurized fuel tank and how about the antilock brake sensors... I just have a few questions =). I'm considering the same swap!!
I want to make my own harness. I have a real good tuner who I can send the PCM to tune, remove emissions and security. fuel tank I am looking @ the summit one. external pump fliter and my engine has a return type fuel system so there is a line going back to the tank. I am looking for a more rat rod fuel system but have not had any info for keeping the EFI but using old school fuel pumps???
New pics.
Old Nov 14, 2007 | 02:21 PM
  #22
Tootall's Avatar
nice progress pics . . . you're going to have to do a bunch of welding with that rotted out floor
Old Nov 14, 2007 | 02:36 PM
  #23
BlackGMC's Avatar
Resident Retard
Very nice! Are you buying or making your own floor pans? If you need any advice on the floor pans, I have a little bit of experience, I made mine from scratch on my mustang..
Old Nov 14, 2007 | 04:12 PM
  #24
actually I am trying to make my own, any tips?? should I use 16g or 18g for the floor??
Old Nov 14, 2007 | 04:31 PM
  #25
Yogi Bear's Avatar
Nice looking project. You're doing a great job! Keep those pics coming!
Old Nov 14, 2007 | 04:44 PM
  #26
BlackGMC's Avatar
Resident Retard
I used 18 gauge cold rolled sheet, but you could use 20 gauge if you wanted too. 16 gauge is way to thick especially if your going to make a tranny tunnel. Get the cold rolled steel instead of the hot rolled, the finish is better, but it is a little bit more expensive. I rolled beads into my pans, which was a B**** to do on 18 gauge but it turned out good.
Oh before you remove the floors make sure to brace up the door openings and across the front and back to keep the cab square... Otherwise you run the risk of your doors never closing properly!!
This how I approached making floor pans. First remove all the bad sections (in my case everything), next make templates out of poster board. Transfer the templates to sheet metal. Next roll some beads into the sheet metal. I attached my sheets with sheetmetal screws to get everything lined up and fully attached, then I removed 1 screw at a time then filled in the hole with weld. Then I welded all the edges with stich welds. I would highly advise using a gas mix instead of flux core. Here are some pics, there a ton more if you click one of the links in my sig.
You can see in this pic the attaching screws. I bend the tranny tunnel around the frame work I made.
Some what finished product
Old Nov 18, 2007 | 08:52 AM
  #27
what did you roll the bead with?? I have been looking and now that I know I can use some 18g I might get the bead roller from summit. I have an only one w/o the dies, but this thing is old, I was thinking about making some dies for it.
nice work.
Old Nov 22, 2007 | 10:58 PM
  #28
CheyenneSuper's Avatar
Awesome project i got a '72 c-10 my friend is trying to get me to put a 5.3 with a 6-speed in and i am seriously thinking about it
Old Nov 23, 2007 | 07:43 AM
  #29
Do it. It is easier than most think, and you get a nice running truck in the end.
Old Nov 23, 2007 | 12:07 PM
  #30
i like the setup because my friend put a 5.3 out of a silverado and a t56 out of a camaro into an 86 regal and with it all stock it runs like a bat out of hell it took some time to do but i think with his help he would be able to point me in the right direction
