14 bolt swap into 89 gmc 1500
Old 08-27-2016, 03:06 PM
TwistedBigRig's Avatar
Default 14 bolt swap into 89 gmc 1500
So if I go out to the pick and pull and I find a posi, 4.10 , gm corporate 14 bolt in an 88 to 98 chevy or gmc 2500 to 3500 truck is it a direct bolt in for my 1500?
Some stuff I read says yes other stuff I read says the 2500 and 3500 trucks were actually 1 to 2 inches wider so the shock mounts and spring perches won't line up.
Any info greatly appreciated. If it's not a bolt in solution I'm just going to pursue a 9inch axel
Old 08-27-2016, 07:00 PM
Custm2500's Rude Friend
1FastBrick's Avatar
It will be an 8 lug but should bolt right in on a GMT 400 truck.
Needs to be from a 4x4
There was a 1500HD / 2500LD 14 bolt 9.5 that had a 6 lug.
Old 09-14-2016, 08:14 PM
GreaseDog's Avatar
doesn't necessarily need to be from a 4x4, just need to be aware that 2wd axles are a bit narrower and compensate for it. A little less backspacing on the rear wheels (the difference is 3" overall, 1.5" per side) will take care of it.
Shock mounts will line right up regardless. 2wd mounts are a bit lower, but a slightly longer shock, and that too becomes a non-issue.
fillpot
03-01-2016 05:51 AM
GREGGO
16
04-11-2002 02:52 PM
Pro Stock John
21
03-14-2002 03:47 PM
Slammed'99
12-03-2001 01:45 AM
Quick Reply: 14 bolt swap into 89 gmc 1500
