Trans AM - HKE 346 - 6spd - 600+rwhp - TX
Old Apr 13, 2010 | 08:20 PM
Powerhouse's Avatar
Default Trans AM - HKE 346 - 6spd - 600+rwhp - TX
My mods are:
New GM LS6 Block
Callies Forged DragonSlayer Crankshaft
Scat Forged H Beam Rods
Mahle Forged Pistons w/4 cc valve reliefs
Precision Race Componets Stage 2.5 CNC'd 5.3 heads milled to a 59 cc combustion chamber 2.02/1.575 valves
Comp Cam 239/242 dur .649"/.609" 111 LSA
Comp 7.375 Hardend push rods
GM LS7 replacement lifters
Kooks 1 3/4" x 1 7/8" stepped headers w/ off road Y-pipe and 3" Flowmaster Super 40
Lucas 42# Flowmatched injectors
Fast 90mm intake
Nick Williams 90mm Throtle body
Rollmaster Double Roller timing chain
TSP Ported LS6 oil pump
ARP Head and Main Studs (12 point)
SLP Pulley
Modified TNT power ring kit - 150 shot (New noids)
Racetronix Pump and hotwire kit
Toyo Drag Radials
Built by HKE
Tuned by RPM - 458 rwhp 432 rwtq on motor and 593rwhp 605rwtq on a 150 shot
Trans:
Tremec T-56 six speed
Pro 5.0 Shifter
McLeod Street Twin Borg & Beck Clutch
McLeod Adj Master Cylinder
New GM Slave Cylinder
Rear:
GM 10 bolt w/ 3.73 ratio
Brakes:
Bear Eradi-Speed cross drilled and slotted rotors (2 piece front, 1 piece rear
Hawk HPS Pads
Body:
BMR weld in subframe connectors
The car is in really good condition. I believe it was in a minor accident from the previous owner. But it wasn't bad. Still has a clean title (in-hand).It's a 99 and the body has 139k and the motor is right around 10500. Also, when the A/C is on it will hunt for idle at a stop (sometimes die) which you can get tuned. It also has a slight leak, so if you use it often, it'll take about a can a month. Located in North Texas. The rollcage in the pics isn't included.
$11.5 with nitrous, $11k without.
Old Nov 5, 2011 | 09:40 PM
dakota0990's Avatar
I'm interested in talking to you about your car. I live in south east Texas, so a visit would be easy. Let me know something if you are interested. 4095501523
Texas5.3_1251
Mar 5, 2016 08:10 PM
06 4.8
Sep 11, 2015 10:36 AM
11MPG
Sep 8, 2015 04:52 AM
Mark_k
Sep 7, 2015 10:15 PM
MadDMax66
Sep 5, 2015 01:27 AM
