1999 Z28 H/C/I FORGED 347 10 second car
Old Mar 7, 2010 | 11:15 PM
Z28FirefighterI1's Avatar
10 Second Club
Default 1999 Z28 H/C/I FORGED 347 10 second car
Sold.................
Old Mar 31, 2010 | 08:39 PM
Team Paulie's Avatar
Registered User
man all the Florida boys get to have all the sweet toys. BUMP FOR YOU
Old Apr 13, 2010 | 03:44 PM
sickREDsierra's Avatar
gorgeous car ! bump for you
Old May 10, 2010 | 08:43 PM
scotthughes's Avatar
Banned Scammer
beautiful car. automatic or manual?
Old May 11, 2010 | 04:03 PM
SILVERADO11's Avatar
One sweet F-Body! good luck on the sale! wish i could be the proud owner of that beast!
Old May 31, 2010 | 02:45 PM
crazyjay2101's Avatar
gorgeous car good luck with the sale.
Old Sep 9, 2010 | 05:12 PM
10 Second Club
Ok guys just updated the info on the car, I was bored with the auto trans to I installed a new fully built viper spec T56 6 speed manual trans, trans now has 1k on it. I'm open to trades.
Old Sep 10, 2010 | 01:56 PM
10 Second Club
It also has brand new Nitto NT05's on the rear less than 1k miles on them.
Old Sep 10, 2010 | 04:00 PM
00buckshot's Avatar
Wow, Wish i could afford this car I have been wantin an
F-body bad!
Old Sep 12, 2010 | 06:52 PM
10 Second Club
Here's the complete mod list for the car......
CHASSIS --
BMR Chrome Moly Adjustable Torque Arm - $374.95
BMR adjustable Panhard Rod - $114.95
BMR Boxed Lower Control Arms - $174.95
BMR Control Arm RELOCATION BRACKETS - $89.95
BMR Boxed weld-in Subframe Connectors - $159.95
Spoon Drag rear swaybar with 9” kit - $239.99
BMR extreme Strut tower brace - $179.99
8 point chromemoly roll bar -$1800.00
Driver side Corbeau Racing seat with 5 point harness - $450.00
F-body Seat brackets - $188.00
Lakewood D/S Loop - $54.99
TOKICO HP Series Front Shocks -$279.90
HAL QA1 12 way adj Rear shocks -$359.98
V6 rear springs -$50.00
SMJ ABS delete with line lock and proportioning valve - $209.99
ENGINE--
Forged 347 built for nitrous by Redline Automotive Labor
Labor and machine work - $1700.00
Wiseco Forged Pistons - $601.99
Mahle Performace Piston Rings - $105.95
SCAT – H-beam forged 4340 with ARP 2000 alloy 12 point bolts - $555.95
Clevite 77 Bearrings throught - $189.99
LS2 Timing chain set - $90.99
Texas Speed cam Magic Stick V.3 237/242 .603/.609" 113 LSA - $374.99
Ported LS6 oil pump - $159.99
GM LS7 lifters - $129.99
Crane Pushrods 7.4 Chromemoly harded - $119.99
Cosmetics MLS head gaskets 0.040” - $139.99
ARP 12-Point Head Stud Kits - $279.99
Metco crankcase breather - $46.99
Spohn Polyurethane Motor Mounts - $69.25
TA lower Ram Air box - $150.00
SLP Lid - $99.99
K&N Air filter - 59.99
SLP smooth bellows - $69.95
MSD Plug Wires - $61.99
03 truck coil packs - $100.00
SLP Harmonic Balancer/Underdrive Pulley – $199.95
160 Thermostat - $59.95
Racetronics Walboro 255 fuel pump with hot wire kit - $210.00
42lb ford green top injectors - $324.99
Professional products Aluminum Fuel rails - $122.99
Auto Meter 2174 Fuel Pressure Gauge - $29.99
LS6 Intake - $300.00
Ported and polished TB with bump stop mod - $75.00
Patriot Performance CNC Ported 243 LS6 2.02"/1.57" 59cc Heads $1295.99
Patriot gold .650 valve springs
Titanium locks and retainers
Stewart Warner 114951 2-1/16'' Ultra Shift Tach -$167.95
Brand new optima battery 75/35 red top -$159.99
NITROUS --
The NX Gemini Twin EFI system replaces the factory MAF sensor housings on LT-1 and LS-1 GM cars. This 6061-billet aluminum high flow MAF assembly offers up to two nitrous outlets for adjustable power up to 300 horsepower. - $1069.99
Upgraded to a 2 stage system - $200.00
Nitrous system Purge - $80.00
Nitrous Outlet F-Body Dedicated Fuel Systems for nitrous system - $715.85
Auto Meter 2173 Fuel Pressure Gauge - $29.99
NX Fuel Pressure Safety Switch - $64.99
15lb NX nitrous bottle
LS1 Timing Tuner & Nitrous Controller - $289.99
MSD digital window switch -$129.99
180 performance F- Body Spare Tire Area Bottle Bracket - $44.99
180 performance Heated Bottle Bracket - $146.99
Auto Meter 6174 Nitrous Pressure Gauge -$199.99
EXHAUST --
Ceramic coated Long tube headers 3” to 3.5” ORY - $479.99
QTP 3.5" Electric Exhaust Valve & SS Cutout - $204.99
Magnaflow LS1 SS Catback Exhaust System -$479.99
TRANS and REAR END --
Billingsley Racing Ford 9” 35 spline axles and Detroit locker differential - $2500.00
D&D performance built tranny - $3495.00 BA8V F-Body Chevy/Viper T-56
750 lb-ft Torque Capacity
26T Input Spline
30T Output Spline
Gear Ratios: 2.66, 1.78, 1.30, 1.00, .74, .50
Carbon Fibre Blocker Rings
Billet 3-4 Inserts
Manganese Bronze Shift Fork Pads (1st thru 6th)
Reverse Inhibiter
Textralia OZ 700 Series Z Grip Clutch kit - $1450.00
Tick Performance Adjustable Clutch Master Cylinder Kit - $339.99
GM Slave Cylinder & Throwout Bearing - $159.99
Pro 5.0 Shifter and Lou's Short Stick Package - $215.00
Tick Performance Remote Clutch SPEEDbleeder Line - $49.99
Harlan 2 step - $249.00
Precision Shaft Technologies – Custom 3.5” Aluminum Racing drive Shaft - $429.99
1350 Series Race Yokes U-Joint Girdles - $33.99
UMI Torque Arm Relocation Trans Cross member - $239.99
APPEARANCE --
SLP ultra Z hood - $899.99
SS spoiler - $299.99
Fresh paint just painted 1yr ago - $2500.00
17” torque thrust wheels 17x9.5 front and 17x11 rears - $1199.80
Stereo
Pioneer radio
2 kicker 12” comps
1000 watt excursion amp class D
Amp capacitor
Other Stuff that goes with the car
Set of 4 OEM chrome 10 spoke SS wheels, good back up set fair condition
Passenger side racing seat bracket
Factors drivers side seat
Complete AC system that worked but I never reinstalled
A lot of the stock parts
