Transmission
If it is a 4L80 yes.
The Allison I am not sure about
strutaeng (09-19-2022)
Will the 6.0 actually run an Allison? I've never heard of that.
Also, does the Allison have a separate ECU control? I bought an 8.1/Allison combination with wiring harness and ECU. There's a connector that doesn't have anything connected to though. It looks like an ECU connection, but smaller.
It should run the Allison but the Allison has its own TCM so getting them to play nice might be a little difficult
strutaeng (09-20-2022)
Allison has its own TCM so you will need that and I believe you will have to reprogram your bcm for it as well.
dmoss69
02-02-2008 10:11 PM
