lowering a 2005 2500HD
ok well, im slipping into this world of 8 lug performance. and im looking at a 2500HD duramax. and lowering parts are hard to come by so i need some help. i was thinking of a big drop. where should i go?
Are you dealing with 2wd or 4wd truck?
For the 4wd truck, the most you can go is 3/5 drop. I have a DJM 3/5 drop on my 2005 2500HD. You can only go 3" in the front because of the CV angles and 4wd components.
For the 2wd, the next step past a 3/5 would be a 6/8 drop.
Manufacturers for either kit would be DJM, McGaughys, Belltech.
I like my DJM kit. I would have preferred to go with McGaughy spindles up front by you have to run 17" wheels.
On the rear of my truck, I'm running the DJM shackles & spring hangers. I've also removed one of the spring out of the pack. I'd like to remove the overload because I have bags to compensate. I built and installed a C-Notch for the rear because it allows more travel and a spot for the airbag.
Go here and look at post #7. Not my truck, but everything is the same except the color. http://www.dieselplace.com/forum/sho...d.php?t=359134
