gas in diesel tank, bad news?
i would say yes detination is bad when it comes to gas it probably made a big boom. i believe gas has a lower flash point than desiel so the compression haet and gas probably done you in.
Gas will definately destroy your diesel engine.. Gas will pre-ignite before the piston reaches TDC and try to force the motor to spin in the opposite direction, causing bent rods, and usually broken cranks in Powerstrokes..
lxcoupe
Sep 6, 2017 08:24 AM
GM1697
Sep 9, 2015 01:52 PM
