engine oil temps
Old Aug 9, 2006 | 08:06 AM
Whippled 496's Avatar
Default engine oil temps
Just wondering about the efficiency of the stock (in radiator) oil coolers. When i installed the Dmax radiator, i had to install an external EOC because the DMax radiators have no oil cooler in them. I bought a B&M 24,000gvw oil cooler and installed it in the front of the stack, just below my tranny cooler, it gets a good flow of air from the lower section of the grill and from the factory cutouts in the bumper.......
Since I have no way to measure the temps of my oil, i was wondering if this B&M cooler is working as well as the ones in the radiators? Any thoughts? I kept the 1/2" I.D consistant, using 1/2" I.D oil lines and fittings so there is no flow restriction.
Old Aug 9, 2006 | 01:23 PM
Zick's Avatar
Its probably just like the trans cooler, after market ones are almost always better than factory ones.
IMHO
Old Aug 9, 2006 | 01:38 PM
IMHO
I would hope so too, i was just wondering if anyone could confirm it. What does our EOT's usually run?
Old Aug 9, 2006 | 01:45 PM
RoninsDenali's Avatar
My EOT is typically around 170-180F during highway cruising. (0w30 Mobil 1, using 5w30 its higher around 180-195F) After running the engine hard for a few minutes it will climb in excess of 220-240F.
For Reference, the oil temp in my C6, crusing it stays around 215F, granted airflow isnt a corvette's greatest attribute.
One of the things i would love to know, is what the Power Steering temperature on these trucks run at... I look at the tiny little cooler and just shake my head.
Old Aug 9, 2006 | 02:35 PM
silver-mod-o's Avatar
Hunt&Fisherator
I would think you could put an electric temp sending unit right in the line and run a guage off it to get your EOT... then just mount it in the cab wherever. I am sure your setup will cool better than stock though.
Old Aug 9, 2006 | 04:57 PM
Eye-P's Avatar
Here is a great writeup about what is the most well thought out oil cooler solution I have seen.
http://www.xse.com/leres/ss/oilcooler.html
The oil tanks in the rad are there to heat up the oil quickly as well as to cool. They dont work all that well.
Old Aug 9, 2006 | 07:37 PM
Originally Posted by Eye-P
Here is a great writeup about what is the most well thought out oil coller solution I have seen.
Very cool (no pun intended), thanks EYE!
Old Aug 10, 2006 | 07:10 PM
I have never seen mine over 200* since I installed my engine oil cooler, it usually sits around 180*, 190* in +100* weather.
Oobray
Jun 13, 2022 03:38 AM
ullose272
Aug 5, 2016 02:05 PM
Noah Burns
Sep 7, 2015 05:50 PM
ullose272
11
Jul 17, 2015 07:22 AM
Mzay
Jul 6, 2015 11:03 PM
