Cluster ?s
Old Jun 11, 2010 | 07:42 PM
Oldtoad's Avatar
Default Cluster ?s
My instrument cluster went out, second time. Now there is no warranty. I have a chance to buy one out of a Escalade for $120.00. He said he had it in his DuraMax Chevy but did not re-program it for the truck.
I was under the impression that the cluster had to be programed for each vehicle due to tire size, gas tank size, rearend ratio, ect...
Has any body changed out theirs and what did you do?
Old Jun 11, 2010 | 10:53 PM
04Silverado5.3's Avatar
Clusters only need to be programmed for mileage and hours so that it matches your current mileage and engine hours, but is not necessary to make the cluster work. All of the other data is sent from the PCM via Class 2 Serial Data.
Old Jun 22, 2010 | 10:20 PM
bighoss77's Avatar
whta on your cluster went out? the guages or the odometer/PRND321 display? if its the display, there is a fix for that. i just fixed mine... took about 30 mins total.
Old Jun 30, 2010 | 10:21 PM
Oldtoad's Avatar
Everything went out. I only have lights.
Old Jul 1, 2010 | 02:03 AM
bighoss77's Avatar
ooh, i know of a problem with the odometer/gear selecter display thats common. one of the pins has a bad solder job on the back, by adding solder it will fix the odometer/gear display... not sure about the rest, could be due to the same bad solder connections?
Old Jul 8, 2010 | 10:21 PM
camochevy21's Avatar
I swapped out my cluster because my spedo wasn't working, all I did was unplug and plug. I got my cluster out of digital dash solutions and they programmed everything for me.
dantheman1540
Feb 24, 2016 09:56 PM
zblee
Sep 17, 2015 07:58 AM
fiatdale
Sep 11, 2015 02:07 PM
andrewlong
Sep 8, 2015 10:25 PM
silver-mod-o
Sep 7, 2015 10:22 PM
