Cam and no converter..
Old Oct 22, 2014 | 11:17 AM
LQ4 Tank's Avatar
Default Cam and no converter..
Alright, so here's the deal. Talking to Martin over at Tick now, he's figured out a cam for my build. It will be going into my turbo build, but plan on putting it into my N/A motor for now just to run around with some lope and more power! I'm not sure on how big it'll be, no lift or duration numbers or anything, just wanna learn more about this: Is it aboslutely necessary to run a higher stall with a cam, or is it just a racing thing? That's a lot more money to throw at the build right now that I wasn't looking forward to, haha. It's my daily driver and sees a lot of stop and go, and from what I understand the 4L80 has a higher stall already, so what's y'all's input?
Old Oct 22, 2014 | 03:12 PM
Txblue's Avatar
What are the specs on your truck. Is it your 2001 2500? Im guessing 6.0 with it being hd and 4l80.Makes a difference if its a single cab or 4 door. And 2wd or 4wd. And gear and tire size.
Old Oct 22, 2014 | 03:43 PM
LQ4 Tank's Avatar
Yeah it's the big rig. 2001 Sierra 2500 HD, four wheel drive, LQ4, 4L80, 3.73 gears with "35" inch Toyo's, really measure out to be 33's. I plan on going to 4.56's soon though. Crew cab. Weighed in at 6,800 on the scrapyard scales.
Old Oct 23, 2014 | 11:12 AM
Txblue's Avatar
With the 4.56 gears a cam between 212 to 220 duration should be fine in a 6.0 with stock converter. I have a 214/218 cam in my 5.3 with stock converter and its fine.
Old Oct 23, 2014 | 12:50 PM
Alvin@PCMofNC's Avatar
Truck Sponsor
It is not necessary to have a converter with a cam, but it does require certain specs. If you go too big with it on the stock converter you will encounter driveability problems.
Old Oct 23, 2014 | 12:53 PM
LQ4 Tank's Avatar
Thanks for the help man, I may swing this over into LS1Tech and see what they have to say. Little more active over there. No body likes playing in trucks
Old Oct 23, 2014 | 01:35 PM
black00chev's Avatar
Slowest turbo build ever!
There's plenty of activity here trust me! We just don't like to be redundant.
But like Txblue said, you'll be fine. But an aftermarket converter will drastically improve how well it runs.
Old Oct 23, 2014 | 01:43 PM
Vortec350ss's Avatar
he nailed it. And how well it runs in every way. Better manners (as long as the converter isnt too loose), and much better performance.
Old Oct 28, 2014 | 09:31 AM
LQ4 Tank's Avatar
Thanks guys! That relieves me of some money for now! I plan on throwing in another converter eventually, just not now.
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
