Building '00 2500 4x4
Old Jun 6, 2016 | 09:47 PM
FFDP's Avatar
99-00 was the iron heads. So look for a late 2000 and up part out or how ever you want to find them.
Old Jun 6, 2016 | 10:09 PM
Haulinbass02's Avatar
So pretty much ANY aluminum head from '01 and up should do? Stupid GM changed stuff around so much it's hard to keep up with what is what. I need a shopping list of what head is on what and what years....😡
Old Jun 7, 2016 | 03:33 PM
Ok, so I think I'm understanding more about GM and their craziness. I'm actually looking now at a '02 LQ4 that has the 317 heads. Its in pieces right now. Machine work done on block, everything cleaned and ready for assembly. I think I might just buy that, assemble it with new TSP cam, springs, pushrods etc, that way when I pull the old engine I can just drop the rebuilt one in and have minimal downtime.
Old Jun 7, 2016 | 06:36 PM
Wolftrk99's Avatar
Probably better way to go just make sure you get a flexplate and adaptor for it.... Not sure if your flexplate will work with an adaptor or not...
Old Jun 7, 2016 | 06:49 PM
Both motors are in front of 4L80e trannys. I thought my motor in the '00 was the only one that had a flex plate with an adapter? I thought the newer ones mated up directly?
Old Jun 7, 2016 | 08:49 PM
Wolftrk99's Avatar
You have that backwards, the early 6.0s with cast heads mate directly to 4l80 after they started putting the 6.0 in escalades and denalis they changed the crank to mate to a 4l60 and when mated to a 4l80 they had an adaptor and different flexplate...
Old Jun 7, 2016 | 10:02 PM
Well that sux. They actually changed the crank so I can't even swap MY flex plate onto the other motor and stab it back in.....I better make sure this other one has the flex plate and adapter then. Thanks for the info once again.....
Old Jun 7, 2016 | 10:40 PM
Wolftrk99's Avatar
If you need it you can get a replacement flexplate with adaptor and bolts new aftermarket for like $68-70 online... Ive been preparing for when my self built 60 takes a sh....
Old Jun 7, 2016 | 10:57 PM
Wolftrk99's Avatar
https://www.performancetrucks.net/fo...-parts-544461/
If youre still looking and hadnt seen this yet....
Old Jun 7, 2016 | 11:24 PM
Hadn't seen it but now hopefully I can buy them. Thanks
JC94Z28
Mar 21, 2016 12:56 PM
About20ninj45
20
Mar 1, 2016 08:58 PM
Garrett12895
Feb 22, 2016 10:42 AM
